TSB: Oil Leak From Front Timing Cover '05-'08
Discussion in 'TSBs' started by s/chargedxrunner06, Dec 23, 2007.
  1. s/chargedxrunner06
    s/chargedxrunner06 Toyota Master Tech
    Feb 20, 2007
    1,166
    Thought I would add this to the list of TSBs, mine leaked at 1000 miles and we have done a lot of these on the 1GR-FE for the timing chain cover leak, the leak will start on the passenger side of the motor around the power steering pump between the timing cover and engine block.
    ADMIN EDIT: added new TSB pages
      File size:
      48.2 KB
      818
      File size:
      33.2 KB
      564
      File size:
      46.6 KB
      576
      File size:
      42.7 KB
      654
    #1 s/chargedxrunner06, Dec 23, 2007
  2. 4VsX
    4VsX New Member
    Jan 20, 2007
    426
    does that tsb say dec 6th?
  3. s/chargedxrunner06
    Feb 20, 2007
    1,166
    Yeah it's Dec 5, 2007 because it is a updated TSB from the 05,06 and 07 models and they have just included the new 08 model
  4. Stevenredx
    Stevenredx New Member
    Good stuff Jim, thanks :top:
  5. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    yeap..mine just started...going in tomm. to get it taken care of...
    Thanks ArkansasX for the heads up on it/as well as Glen from TTC for pointing it out to me..:top:
  6. ntinhri
    ntinhri Active Member
    Feb 1, 2007
    8,104
    anyone else you want to thank? your mom, dad, your hot wife, your dog, ect???lol
    Now I need to check for this leak!!
  7. dak-rt-2a-XR
    dak-rt-2a-XR Banned
    Jul 8, 2008
    3,234
    id like to thank the academy, all my friends, and all those who i dont know and have nothing to do with this
  8. My68ur8trd
    My68ur8trd Active Member
    4,672
    I just found this yesterday. I will have it looked at the next time its in :top:
    Justin
  9. eltus
    eltus Member
    Mar 25, 2008
    618
    good stuff. that will be something to keep in mind when I get back!
  10. jimx
    jimx Member
    135
    will the toyota extended warranty cover this? mine started leaking after the nst pully installed.
  11. LOW AND BLOWN
    LOW AND BLOWN Active Member
    Sep 25, 2007
    1,020
    Hmm you dont say....Put your OEM back on :top:
  12. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,960
    68
    Just had my X checked by the dealer and they confirmed my leak was covered by this TSB.
    I have to go back in next Monday for them to pull the motor and fix it! :thumpdown:
    At least they'll give me a loaner while it's being done.
  13. ICEMAN
    ICEMAN "I drive in the dirt"
    Jul 21, 2007
    1,578
    I wish I was still under warranty to get this covered.
  14. Generation-X
    Generation-X New Member
    Jan 10, 2009
    1,240
    Anyone have an actual shot of where this leak is supposed to be at. Mine is leaking from near there and would be awesome if its related lol
    Found a pic of the cover. Mines leaking from near where the curve is to the left of the cover?
    #14 Generation-X, Sep 9, 2010
  15. XRnRElite77
    XRnRElite77 New Member
    Apr 10, 2007
    1,139
    the leak starts where the PS pump mounts to the block, its too tight and causes the TC cover to be pryed away from the block, its retarted that TOYOTA mech dont fix the problem instead of the issue. they fix the leak but not what causes it. the TSB says nothing about replacing the PS pump or milling the bracket. :thumbdown:
    red - issue with why it leaks, top bolt location needs to be about 1/16 thinner
    blue - where the leak accurs.
    #15 XRnRElite77, Sep 9, 2010
  16. ntinhri
    Feb 1, 2007
    8,104
    I havent had this issue..........
  17. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,960
    68
    No pics, but the TSB say it's "where Bank 1 cylinder head, engine block, and timing cover meet."
    When facing your engine, it's on your left (passenger side). See the diagram on page 4 of the TSB in the first post.
    Mine was grimy behind and below the pulley on the vane pump assembly. If you crawn under your truck, you can look up and see how dirty it is up there!
    Don't know if I can get a good shot of it, but I'll try...
    Edit:
    Front Top View:
    Bottom Side View:
    #17 BSP06XRU, Sep 9, 2010
  18. Generation-X
    Jan 10, 2009
    1,240
    Yep thanks guys. Thats where my issue is too. Guess im needing a call to the dealership tom and maybe even a rental vehicle, ill ask for something sporty if I can get it LOL
  19. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,960
    68
    The TBS says the repair is covered under the Toyota Powertrain Warranty (60 months or 60,000 miles). Don't know if extended warranty covers it. Good luck! :top:
  20. Generation-X
    Jan 10, 2009
    1,240
    Mine hasnt topped 60K yet so im hoping to get in soon. Still at like 58k
