Tundra Master Cylinder and Brake Booster Upgrade For The Tacoma's
Discussion in 'Aftermarket Brakes' started by gbxrunner, Feb 21, 2017.
  1. gbxrunner
    gbxrunner New Member
    Aug 5, 2014
    13
    Master Cylinder Tundra 2007+ Sequoia 2008+
    Brake Booster Tundra 2007+ Sequoia 2008+
    Custom SS Brake Lines
    Custom Clutch Fluid Reservoir
    Custom MC Fittings
    Torspd likes this.
  2. flipboikev
    flipboikev RamRod Parts
    Feb 20, 2016
    87
    18
    Is the Tundra brake booster direct bolt on?
    Are you running bigger brakes?
    How is the pedal feel?
  3. gbxrunner
    Aug 5, 2014
    13
    My XRunner has front BBK 360mm and Rear Disk Conversion 345mm from Performance Brakes Unlimited.
    Pedal feels great.
  4. SgtBadA
    SgtBadA Member
    Apr 21, 2013
    562
    17
    The tundra master cylinder is a disc/disc master. Did you have to run a proportioning valve? I'm curious as to how that is working out. Did it directly bolt on?
  5. gbxrunner
    Aug 5, 2014
    13
    Hi there;
    No proportioning valve required, The ABS pump, ECU along with the ABS sensor on each wheel monitors speed and movement to prevent any brake locking on the brake system, I have been using this set up for almost a year, no issues.
    The Booster will bolt on into the fire wall, everything else need a custom hardware kit available at Performance Brakes Unlimited.
    Also If there's anybody around Houston that would like to test my Truck (Brakes), just let me know we can set up a day.
    Thanks
    #5 gbxrunner, Feb 21, 2017
    Torspd likes this.
  6. SgtBadA
    SgtBadA Member
    Apr 21, 2013
    562
    17
    I live in Fort Worth I may take you up on that offer of testing them. The kit looks awesome. It will definitely be going on the list of mods in the near future. One last question, do any of the sensors on the master cylinder cause any of the daah lights to light up? I'm guessing they match up perfectly.
  7. gbxrunner
    Aug 5, 2014
    13
    Hello there.
    Nop, everything fits perfectly, No lights up. Just OEM.
    Let me know for the test drive.
    Thanks
  8. Doublld
    Doublld Active Member
    Jun 12, 2013
    1,089
    20
    what is the biggest difference between the oem booster an master compared to the tundra?
  9. gbxrunner
    Aug 5, 2014
    13
    Tacoma: single diaphragm 11.250in, MC 13/16
    Tundra: double diaphragm 9.745in, MC 15/16
  10. x-runner kid
    x-runner kid Active Member
    Oct 11, 2007
    1,323
    16
    So how much is it gonna cost for the kit and what all is included and what all do we need to buy outside of the kit?
  11. gbxrunner
    Aug 5, 2014
    13
    WHAT MASTER BRAKE CYLINDER AND BRAKE BOOSTER?
    TOYOTA TUNDRA 2007 -2015, SEQUOIA 2008-2014.
    MC BRAKE LINES?
    MC BRAKE LINES NEED'S TO BE REPLACED TO LONGER ONES. ONE OF 72" AND ONE OF 75".
    YOU CAN ALWAYS REUSE YOUR EXISTING BRAKE LINES, IF YOU HAVE THE SKILLS TO WORK WITH THEM, YOU CAN DO IT. I WILL RECOMMEND NEW ONES.
    ALSO BRAKE LINES WILL BE AVAILABLE TO BUY FROM PERFORMANCE BRAKES UNLIMITED. EXACT LENGTH COILED BRAKE TUBING WITH FITTINGS ALREADY ATTACHED, THEY JUST NEED TO BE BEND TO FIT. PROFESSIONAL INSTALLATION RECOMMENDED.
    WHAT THE KIT INCLUDES?
    ALL HARDWARE TO INSTALL BRAKE BOOSTER TO THE FACTORY BRAKE PEDAL AND MC FITTINGS TO RECONNECT BRAKE LINES.
    WHAT ELSE DO I NEED TO COMPLETE THE UPGRADE?
    MASTER BRAKE CYLINDER.
    BRAKE BOOSTER.
    LONGER BRAKE LINES.
    THE XRUNNER AND TACOMAS WITH MANUAL TRANSMISSION WILL NEED A SEPARATE RESERVOIR FOR THE CLUTCH (BRAKE) FLUID. FOR EXAMPLE A MOTORCYCLE BRAKE FLUID RESERVOIR.
    WHAT MODIFICATIONS DO I NEED TO DO ON MY TACOMA?
    LONGER BRAKE LINES.
    YOU NEED SEPARATE CLUTCH RESERVOIR (FOR MANUAL TRANSMISSION ONLY).
    EVERYTHING ELSE IS EASY BOLT ON.
    HOW MUCH FOR THE KIT?
    SALE IS $109.99 XRU members will get a 10% discount AND FREE SHIPPING lower 48 states.
    FOR DISCOUNT CODE PLEASE PM.
    HAMHAWK_JAY likes this.
  12. SgtBadA
    SgtBadA Member
    Apr 21, 2013
    562
    17
    Not a bad deal. A proportioning valve would be needed if keeping drum brakes in the rear.
  13. x-runner kid
    Oct 11, 2007
    1,323
    16
    That's a good deal for sure now I just need a rear disc conversion so I can justify this lol.
  14. gbxrunner
    Aug 5, 2014
    13
    More info about ABS.....A standard Anti-lock Braking System uses four wheel speed sensors, a hydraulic pump, four hydraulic valves (assuming it is a 4 channel setup), and a controller. The controller in the ABS system monitors the speed of each wheel using the wheel speed sensors, which are usually hall effect sensors. If the controller sees that one wheel is decelerating at a rate that couldn't possibly correspond to the vehicle's rate of deceleration, it actuates the hydraulic valve in that wheel's brake line to reduce the brake pressure applied to that wheel. This allows the wheel to turn faster. Once the wheel is back up to speed, it uses the pump to introduce the pressure back into that brake line, applying that brake again. When the controller sees rapid deceleration again, it activates the valve and the cycle repeats about 15 times per second. This happens the same on Disk/Drum and/or Disk/Disk.
  15. SgtBadA
    SgtBadA Member
    Apr 21, 2013
    562
    17
    I'm only worried about the master locking up the rear brakes before the front. I haven't converted to disc in the rear yet. Drums work a little differently so my guess is that a proportioning valve is needed if keeping drums
  16. NetherRealm
    NetherRealm New Member
    Mar 28, 2017
    Brakes are the first mod i'm looking to do on my XR. I was looking at the Stoptech 6 pots but this might be better as its using OEM parts. I might as well do the front/rear disk conversions and the booster all at once.
  17. SgtBadA
    SgtBadA Member
    Apr 21, 2013
    562
    17
    I'm focusing on this too. I've already got the tundra front brakes. They stop great just need that little extra pedal feel from a bigger master cylinder
    x-runner kid likes this.
