Urd fuel pump filter...
Discussion in 'F/I Mods & Tuning' started by sdxrunner619, Feb 4, 2012.
  1. Whitebeauty
    Whitebeauty New Member
    Oct 15, 2011
    5,237
    Oh yeah u can do it yourself. i did, and had a little help over the phone from my buddy 1GR
  2. Blasphemous
    Blasphemous New Member
    Oct 11, 2011
    324
    Cool, I imagine it comes with instructions, which I will read 1bazillion times before the install.
    Looks like I am sending some more moo-lah Gadgets way :). :top:
  3. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    A common Walbro 255 (if you didnt already replace your OEM pump) and a external quality fuel filter is all you need.
    I like the spin on water separating, 5 micron, high flow, multi input/output fuel filter setups that RAMCO offers. They are compatible with all methanol, ethanol, race fuels, etc...
    http://www.ramcoperformance.com/flomax.htm
    You can do both the pump and filter setup for around $185.00
    You can also change the filter one handed with out jacking up the truck or getting under it.
    Really its a great filter setup for the money and is what I ran on my truck with all kinds of fuel.
    #23 5H4D0WD347H, Feb 4, 2012
  4. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,766
    13
    Yeah I did it myself also, since youve never done it before just make sure to reserve an entire afternoon for it. Just dont do what I did...
    Jacked up truck,
    Dropped tank,
    Busted out the dremel and crimpers and went to town,
    reinstalled tank,
    dropped truck,
    turned ignition on, heard absolutely no fuel pump noise,
    got blind with rage,
    jacked up truck,
    dropped tank, again,
    checked all connections,
    reinstalled tank,
    dropped truck,
    turned ignition on, still nothing...
    then I realized that the fuel pump on this truck doesnt kick on with the ignition. It kicks on when the starter does. It made me feel like a complete jackass. I clicked the starter for a quarter of a second, and heard the fuel pump buzz to life and pressurize the fuel lines...I wanted to point and laugh at myself lol.
  5. 5H4D0WD347H
    Apr 24, 2007
    10,450
    Oh snap mark.... You bastard didnt see your post.
    lol.
  6. Blasphemous
    Oct 11, 2011
    324
    Oh wow that would drive me insane if I expected it to turn on and it didn't...
    Would you guys suggest confirming that the pump works before I go to install it? I imagine it will work, but I would hate to be chasing my tail attempting to diagnose an issue that isn't really my problem.
    And I don't think I will have to jack my truck up thankfully :)
  7. justin13703
    Sep 9, 2010
    2,766
    13
    I don't think it would be good to run it dry, im sure they get checked before sending them out. If you just make sure your connections are solid, you really shouldn't have a problem. You may be able to connect it to the battery for a quick second to make sure it kicks on, but it might not be great on the pump to do that. Someone may know more than me if there is a way to test it.
  8. Tunedx
    Tunedx Active Member
    Dec 23, 2007
    3,084
    When u go this route how would u bypass oem fuel pump and where did u mount this pump?
  9. 5H4D0WD347H
    Apr 24, 2007
    10,450
    Just drop the pump in the tank bucket... Secure it with a stainless cable tie if you want it to be quick and easy. Its hard to explain with out you seeing what im talking about but once you take it all apart you will understand what you need to do, its pretty self explanatory.
    Mount this filter setup underneath the truck to a part of the frame (crossmember) and your fuel comes in and goes out :-D.
    Then to change the filter all you do is reach under the truck, unscrew the old filter, and spin on a new one (like an oil filter).
  10. Torspd
    51
    I'be now the ability to do it in 30 minutes. Literally. 4 jack stands, and a motorcycle jack for the tank are how i do it. A regular jack will work as well. Just be sure to be less than 5 gallons in the tank. :top:
  11. Blasphemous
    Oct 11, 2011
    324
    That's a lot of jack stands... would you care to elaborate?
  12. sdxrunner619
    sdxrunner619 Active Member
    Jan 20, 2010
    3,836
    6
    To support the truck on all 4 corners, off the ground, so you can pull the gas tank out. :top:
  13. Blasphemous
    Oct 11, 2011
    324
    Hmmm...
    Is there not enough room to do it without jackstands?
    I have a PreRunner btw. I guess this question is moreso directed at Torpsd because he has a 4x4.
  14. Ridefoxone
    Ridefoxone Member
    Aug 23, 2009
    155
    Does anyone running the URD fuel upgrade kit have any problems choking out with less than a 1/4 tank non supercharged applications? Or is it just the supercharged applications. I know mine starts choking out right at 1/4 tank using the walbro, and has since install. Almost like you loose that 1/4 tank in between fill ups, Just curious
  15. Murderface
    Murderface New Member
    Feb 27, 2008
    11,937
    Never any probs since I installed my URD kit some 2 yrs ago. I also change mine every other oil change, around 10K(can't be too careful cause u can't see what's goin into ur tank). This is useful if u like to run the tank down till the warning light comes on, every once in a while I'll do that but try not to. I always use Sunoco 93 but who knows when ur getting the bottom of the barrel. Wouldn't mind adding a gas/water separator especially during spring/summer when I run E85 a lot
  16. Super Werty
    Super Werty Active Member
    Jul 12, 2007
    6,283
  17. 1GRracer
    1GRracer "Pete"
    Aug 8, 2010
    3,586
    ^yes.........
  18. Torspd
    51
    One guy with a dremel and a few hand tools. :)
  19. Baggins44
    Baggins44 Active Member
    Jan 23, 2010
    1,402
    Thread revive. Anyone ever done a write up on this?
  20. dpartinvr4
    dpartinvr4 Member
    Aug 31, 2011
    865
    You get directions with pictures from urd.
