URD vs TRD Supercharger Info & Stats
Discussion in 'F/I Mods & Tuning' started by quickshift93, Mar 6, 2008.
Thread Status:
Not open for further replies.
  1. 07SWB
    07SWB Active Member
    Feb 14, 2007
    3,603
    i think its pretty easy to stay ahead of the #'s Jon is making if youre meth injected and tuned, Jon's truck at 343whp was with just the toyota ECU flash and no tuning done. With tuning and meth as your truck has, im sure it will be a better comparison.
    Again, the fact that the power comes on a lot faster in a TRD truck compared to a URD truck.
    i would like to see the TRD and URD dyno sheets next to eachother, not just numbers.
  2. LSKustumz
    LSKustumz New Member
    Nov 6, 2007
    377
    Again, I will reiterate, I am by no means nay-saying the URD system. I have seen videos on youtube of Jonathon doing a 3rd gear pull and it really wrenched! The rotrex is a proven charger with a definite spot in the aftermarket. And it sounds like URD is coming out with even more add on's for other applications. URD distributes our headers and exhaust I have no reason to speak ill of them. I just want the XRU and general aftermarket public to get all the facts they need.
  3. Super Werty
    Super Werty Active Member
    Jul 12, 2007
    6,283
    For me hp doesn't mean too much when we are talking about these trucks
    either way you go URD or TRD, your going to be faster than stock and about the same to 60, 100 etc
    in all seriousness, you cant go very fast on the street anyways so for me an improved 0-60 and 60-100 is all Im looking for...and improved sound of course:rock::biggrin:
  4. My68ur8trd
    My68ur8trd Active Member
    4,672
    headers and no headers:smile:
    Justin
  5. My68ur8trd
    4,672
    here is a chart to look at
    untuned ... obviously and with stock manifolds this is the slap the 75 and run pull. I now have DT headers and a good tune, but havent put it back on the dyno. This is the same dyno that Steve put down 326 on a few weeks ago.
    #105 My68ur8trd, Mar 29, 2008
  6. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    So this is 6 PSI (untuned TRD) vs. 9 PSI (untuned URD) both with stock headers to the wheel (not the hub)?
    Did you have a Y pipe at all for this run? (just to clarify).
    I must say the graph indicates the properties of each kit well.
    It shows that the TRD in stock boost trim (6 PSI) form has more HP and more TQ down low and through the midrange then the URD at 9 PSI.
    Even up top they are VERY close... But the URD puts out a little more peak power (as to be expected with a Rotrex setup running a 75mm pulley).
    You wouldn't happen to have a stock boost URD graph would you dude?
    Thanks for posting up your numbers, they look good.
    Here is a vague (really not comparable when comparing these two specific trucks but should give us a general idea) break down of RPM and numbers between the kits based on the above two graphs:
    0. @ 2,000 RPMs: TRD 118 HP, 298 TQ vs. URD ?
    1. @ 2,500 RPMs: TRD 150 HP, 318 TQ vs. URD 130 HP, 260 TQ
    2. @ 3,400 RPMs: TRD 210 HP, 325 TQ vs. URD 200 HP, 310 TQ
    3. @ 4,000 RPMs: TRD 248 HP, 325 TQ vs. URD 249 HP, 330 TQ
    4. @ 4,500 RPMs: TRD 273 HP, 319 TQ vs. URD 270 HP, 318 TQ
    5. @ 5,000 RPMs: TRD 295 HP, 310 TQ vs. URD 305 HP, 322 TQ
    6. @ 5,500 RPMs: TRD 309 HP, 292 TQ vs. URD 320 HP, 310 TQ
    7. @ 5,850 RPMs: TRD 310 HP, 285 TQ vs. URD (bouncing off the rev limiter)
    Not to shabby for TRD on stock boost vs URD with about 3 PSI more eh?
    Stock to Stock numbers unfortunately in the case of TRD vs URD are BS really unless you want to make all things equal. The above are 2 trucks with similar bolt ons, one with much more boost then the other.
    If you want to compare stock numbers put a hoover hose connected to a hamster maze on the URD kit's intake piping.
    Who the hell is FI & still bone stock anyway? Almost everyone has an intake and exhaust prior or plans to have them very soon.
    Until you drop the stock airbox onto the URD setup don't compare a TRD blower with a stock box vs a URD setup with its CAI.
    TRD Supercharger Kit W/ Self install: 3,800 bucks.
    TRD CAI W/Self Install: $350.00 (or opt for an intake lower in price)
    ECU Flash: $80.00
    For everything else there is Mastercard.
    #106 5H4D0WD347H, Mar 29, 2008
  7. My68ur8trd
    4,672
    326 was Steve on the smaller URD pulley and DT headers at the wheels ( dynojet). This dyno is a little squirrelly though, it can vary 10 hp between pulls
    I had the Y in that dyno and Stock manifolds
    i need to put mine back on the dyno with the headers and tune
    The TRD will make a little more low end until the rotrex builds boost (until around 3k). i hold 5 psi on the shift
    but this really is a beat to death argument. We ran ride by side ( when I was on the 80 mm), and steve pulled from the dig, we leveled out in the midrange, and I pulled up top. Just as expected. Anyone with either kit has a quick ass truck . With him at stock boost and me untuned on the 75 I pulled ( but not by much and 20-30 hp or so wont be a drastic difference)
    Justin
    #107 My68ur8trd, Mar 29, 2008
  8. 5H4D0WD347H
    Apr 24, 2007
    10,450
    As I said you cant really compare with those graphs if you are looking for defenitive numbers to tell all your friends about; it just gives you a good idea of how each kit compares curve wise.
    That graph stacked against yours above is on stock boost, I don't care how much Steve is making (sorry Steve lol) as its irrelevant to the point. In which case if we are going to sling names lets not forget Jon is making damn near 350 HP (with the DT headers & more boost) with out any tune (running pretty lean), meth, or BS.
    That Y pipe makes a larger differance then you think bro....
    I am not looking to compare peak numbers. I just set them up in a incremental RPM fashion to better enable the power curve of each blower setup to be interpreted.
    Both kits are great & make this truck a blast to drive.
    The nature of the Roots blower is to own the low end, midrange, and to keep up a steady curve to the top - good for extreme drag racing, tire burning, all around street use, and even towing due to its almost instant torque/boost at lower revs.
    The nature of the Centrifugal blowers is known to be/and is more peaky when it comes to the power curve. Good for racing, and more highway based driving.
    Those two graphs reflect these different supercharger attributes nicely.
    I think its pretty damn amazing how 6 PSI and an intake/catback stack up to your setup's curve though.
    Correct me if I am wrong but changing out the rotrex blowers to get more CFM/or running smaller pulleys is trying to accomplish what the roots already has done (get more usable power down lower in the powerbound).
    BOOST ON!
    #108 5H4D0WD347H, Mar 29, 2008
  9. LSKustumz
    Nov 6, 2007
    377
    I couldn't have said it better myself!! Both are excellent kits, and will always be compared to each other. Kind of like Ford vs. Chevy, supercharged vs. turbo, and Batman vs. Joker. Knowing the prerequisites of each kit, and what kind of performance they are looking for, one can choose wisely when it is time for boost. I think everything has been well outlined in this thread and is an excellent source of information.
    Now time for me to get boosted!!:rock::rock:
  10. K2
    K2 Administrator
    9,054
    31
    I agree with you completely. I believe that for the time being, this thread will represent a fantastic resource for people looking for additional information about these kits. I am moving this thread to the Forced Induction forum and closing it at this point in time.
    Thanks to all the participants in this thread for keeping it clean - or at least as clean as possible considering the volatility of this subject.
Thread Status:
