Urgent! Please Help with C2C kit.
Spicy Taco X
I am in the middle of this drop in the back and want to know how am I supposed to torque these nuts when there is so much bolt sticking past the nut?:dontknow: :motz:
Matt's06
If you tried a deep well than something is not right.
Spicy Taco X
I didnt have a deep 19mm, but just found a deep 3/4" so that is working. Only thing now is that my socket is 3/8 drive and torque wrench is 1/2 drive and I dont have an adapter:laugh:
x-stealth
I just dropped mine and we cut the extra off the bolt once the nut was on.
dermaestro
Sorry. Misread your question.
I had the same trouble. I bought blocks from PeePee Boys. The U bolts are too long. You have two options. Use a box wrench and spend hours under there or cut your U bolts down.
I used a box wrench and had the alignment shop torque them down when I got the front aligned.
Yeah - You are going to want to cut some off...
What I usually do....
Put the blocks in... u bolts on... washers and nuts
Put the nuts on as far as you can
then cut a good amount off.... make sure you put the nut on first, you might screw up the thread when you cut it.
uh60rotorhead
Maybe that should have been noted in the instructions that went out with the kit...
If you have a deep enough socket, you dont have to cut them.
edit -
But I will add to the instructions for the future people to do that if they do not have a deep enough socket :)
Did you get my PM about that?
It was mailed to the same address as the kit
