SignUp Now!Use 1000 grit wet sandpaper and lightly sand the areas that look really "orange peely"......then follow that with a 2000 grit wet sandpaper.....make sure to get it all with the 2000 grit, minus the hard to see/reach areas..Then use a buffer with a wool buffing pad and some rubbing compund to remove these wet sanding scratches. After that, use some polishing compund with a foam pad to bring out even more shine.....Follow this with some wax, a good wash, then some had polish...... :top:
