Wet shot Nitrous with S/C
Discussion in 'F/I Mods & Tuning' started by dpartinvr4, Jan 27, 2013.
  1. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    lol id say they did something wrong... Crack a bottle open that is that size and you can flash freeze just about w/e its pointed at (it will probably take half a minute to expel its contents cracked wide open when full).
    That bottle on a small shot should last you 50+ runs lol.
  2. Torspd
    47
    Got a leak somewhere it seems.
  3. dpartinvr4
    dpartinvr4 Member
    Aug 31, 2011
    865
    there's no smell either, and it's not a leak because I would hear it, and I sprayed all the connectIons with water and nothing bubbles
  4. 5H4D0WD347H
    Apr 24, 2007
    10,450
    Just to recap...
    Is the bottle the correct weight right now when full or with any nitrous in it? If not perhaps they blew your burst disc when filling it & handed it back to you....
    If the bottle is full/has some contents in it & nothing comes out when you open it with no line attached, the only other possibility is a massive clog or defect in the siphon tube/valve.
    Id be running a filter on the supply line.
  5. dpartinvr4
    dpartinvr4 Member
    Aug 31, 2011
    865
    After I Got done Testing All My Connections and Opening The Valve All The Way Disconnected, The Bottle Weighed 17 lbs Took It Back, they're Going To Fill It Again. Also, How Do I Compensate My Rpm Window ForThe Fuel And Nitrous In The Line Between The Solenoid And Intake after It Closes, Sorry About The Spaces, swype Doesn't Like The Internet Anymore.
    #25 dpartinvr4, Jun 30, 2013
  6. Torspd
    47
    Fixed it for ya. :top: It certainly does like CAPS though doesn't it? Lol
  7. Miami_X
    Miami_X New Member
    Jan 19, 2012
    652
    Any updates to report?
  8. dpartinvr4
    dpartinvr4 Member
    Aug 31, 2011
    865
    never got around to hooking up the fuel line, just been using it to confuse people lol... I should just sell the kit
  9. Whitebeauty
    Whitebeauty New Member
    Oct 15, 2011
    5,237
    How much?..............
  10. lamia2super
    lamia2super Member
    Jan 27, 2013
    647
    easy! just t that stuck off the fuel like and your done !
  11. skygear
    skygear Member
    Jun 1, 2013
    58
    So, Final verdict? Hooked up and run with it? or decided to part ways.
  12. XMPLRY808
    XMPLRY808 Active Member
    Dec 5, 2014
    402
    74
    What about tuning? Heard would need to pull timing when running nitrous? But what if we have no way to adjust the timing? Thanks. I dm'd shadowdeath but he didn't reply yet.
  13. Torspd
    47
    MAF Cal with timing adjust, AEM FIC, MAP-ECU3. Something like that. Or even a UCON if you have a compatible year model.
  14. XMPLRY808
    Dec 5, 2014
    402
    74
    So tuning the timing is required to run a small shot with trd sc? If not, how big of a shot can you go with out adjusting the timing? Thanks!
