What fails or breaks in the six speed trans
Discussion in 'F/I Mods & Tuning' started by Nashman, May 18, 2019.
  1. Nashman
    Nashman Active Member
    Oct 22, 2015
    425
    27
    I hear alot of people say it's junk and it breaks but what is the fail point's
    I all ready know all about the clutch stuff
    I do find the transmission does not like ot be shifted fast. pretty sure the accumulator in the clutch line is to blame.
  2. 30Birdy
    30Birdy Member
    May 3, 2015
    281
    21
    I wish it shifted more like a Tremec.
  3. Nashman
    Oct 22, 2015
    425
    27
    I just by passed the accumulator valve and it shift so much better now and can now shift fast with out grinding a gear with my short shifter now all to fix now is the ecu eather hp tuners or a link ecu and then finally will be able to slam shift the truck with out it bucking or bogging
    john salgado likes this.
  4. NHXRUNNER
    7,892
    265
    I’ve heard of shift forks failing, the quill shearing off, as well as bad synchros. ::knock on wood:: I’ve only had to deal with bad throw out bearings
  5. Nashman
    Oct 22, 2015
    425
    27
    So the box its self doesn't fail ie strip gears or have case flexing issues causing other issues. Getting rid of the accumulator will help quill were kinda wish I did it along time ago
  6. 30Birdy
    30Birdy Member
    May 3, 2015
    281
    21
    Where/how do you by pass the accumulator?
  7. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    859
    32
    Remove the accumulator then pull the back off and remove the check valve then reinstall and bleed air fro system
  8. 30Birdy
    30Birdy Member
    May 3, 2015
    281
    21
    Are there any negative affects from performing this mod?
  9. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,766
    14
    Basically, the throwout bearings suck, the synchros suck, and the gearing is absolutely horrendous lol. I would try the accumulator removal if I still had my truck.
  10. Nashman
    Oct 22, 2015
    425
    27
    I went to pull mine apart but the inner plate didn't wanna pop out so I just said fuck it and put the union in was rather simple lines pretty much met together with light bending .
  11. Superloki24
    Superloki24 Active Member
    Oct 24, 2009
    246
    26
    I got rid of the accumulator and it gives more pedal feel when engaging the clutch. It's not soft like stock and it's more like what I consider the way a clutch pedal should feel like. It was easy to get rid of, but bleeding the system is a pain unless you have a good brake bleeding system.
  12. blu xr
    blu xr Member
    Jan 13, 2011
    854
    sound simple...any vids or a link to this?
    id like to know if there are also
    only problem ive had (currently has over 200k) is a whining noise when at idle. if i push in the clutch a little, it goes away.
  13. Nashman
    Oct 22, 2015
    425
    27
    that should not happen or at least far less then having the valve in there is no stored pressure any more so the barring no longer spins most of the time.
    only downfall in the valve acts as a hydraulic amplifier so for littel movement in the peda make the pedal slow down giveing you more control in the sweet spot makes it easy to get up and go but makes grinding gear's a common thing . the issue that this cases the baring moves too slow, because when you are feathering it sometimes it will jam up and stick some times causing dents/uneven ware in the quill and causeing the uneven clutch ware, then the fork will start to rub on the throw out baring since the clutch diaphragm is no longer flat causing a funny crip, then the barring just gets wores ect ect ect. all the other toyota like the sicon xb have the same valve and show sighns of the same type of ware but less since the pressure plate is not as strong as ours.
    so the only down fall is once you delete it your pedal engagement will move up in the stroke
  14. TacoSawce
    TacoSawce New Member
    Aug 27, 2015
    20
    I rebuilt my transmission last year. Broken shift fork is something you can look forward to. Also, if you have early gen shift keys for the syncros, you can look forward to the balls and springs flying out when shifting and locking your shifter in place.
  15. mejbro
    mejbro Active Member
    Jul 11, 2016
    116
    41
    Unfortunately, I might be in the same boat...
    2 days ago, I was holding the clutch pedal in first gear as the light was about to turn green, and the truck made a "whump whump" sound and the truck actually started to pull forward. ( Clutch pedal still down )
    I tried to get outta first, but I had to rip it out immediately snapping my shifter at the URD SS coupling... truck stalled, fired back up, got it in 3rd and ran every light and stop sign for about 2 miles... I have "The FIX" with the URD Twin Disc Clutch / Flywheel setup. FML, I just hit 1200 moles with the new setup... but like I say, "it'll grow back"
