What should my next power mod be?
Discussion in 'F/I Mods & Tuning' started by woodex m.e., Dec 19, 2015.
  1. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Hey guys, i rarely start threads but i figured i might get good results from this.
    I recently suffered a slight loss to a cummins ram on the highway and it got me back into the holiday cheer to buy more power for myself. Sounds logical and selfless right? Im looking for fellow opinions of where you think i should go next, or what you would consider doing with my current setup. I have a 2013 double cab, 5AT, TRD supercharger, afe intake, URD catback, and URD 2.825 supergrip Pulley. I have done the Oem fpr mod as well as the 255lph fuel pump.
    Currently i have a URD maf calibrator but i have not installed it. Debating on holding out for the Ucon. My thought is a set of URD equal length headers should be whats next. Given that im a 2013 I know my options are somewhat limited.
  2. Gadget
    10,899
    148
    UCON
    URD TCAI
    URD Spec-U headers
    URD Spec-U exhaust
    That will be the best you can do with out putting boost into it.
  3. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Id like to wait till other things are modded equivalently before i add more boost. I already see 9psi with my current setup. At sea level and low temps (45-55f).
    From what i have been gathering with your headers, is that with the plug in O2 simulator its a bolt on deal with little to no fuss, correct? I have emissions testing , but its only done through the obd2, no sniff test.
    Also id love a UCON, but youre still working on that so ill be patient.
  4. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,766
    14
    Honestly, this may require more effort than you want to put into it, but once the ucon is available for the 09 and up, I'd swap the Trd for a urd supercharger. You'll make much more power and pretty much will be able to upgrade that thing to whatever power level you want. With the Trd superchargers being discontinued you can probably get a good amount for yours and may not have to come out of pocket at all for a urd.
    As for right now, what gadget said is pretty much all that you have left to do. You start adding any more boost and the heat level will start to take away from any power increase you might have gotten.
  5. Redlantern
    Redlantern Member
    Jan 28, 2013
    525
    6
    Upgrade your valvebody while you're at it. Huge difference in shifting. You can go with IPT or level ten. Quite a few people have gone with IPT. I have the level ten valvebody in mines. Either works great. Seems that IPT has the customer service under their belt so id recommend them over the other.
  6. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Yeah i see what you are saying, but im not that dedicated to that much effort. Im willing to do moderate stuff but its also my only vehicle so i can only have it down for a few days at a time. Im ok with sticking with the trd unit. I know i wont get the same levels as the urd guys, but its the path i have already started down. Im just looking around at what others would so if they had what i have, what the next atep would be. Some would go full hog and start over, but i need to build a house.....and that takes more money.
  7. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    I have been heavily considering it. I heard rumor that one of them does a diy kit so you dont have to send the assembly out. Is this true? My plan is to do one more power adder and then the valve body after. Doing it all as funds become available. Ive had the truck for three years and i usually do one or two things a year to it.
  8. Darkside-X
    Darkside-X Member
    Sep 17, 2014
    203
    Another good header choice if you have emissions is AFE Twisted Steel headers. I have had them on my truck for few months now with no issues. Short tube headers with built in high flow cats. They are pricy, but they are better than the short Doug Thorley headers, with cutting your stock cats off and welding on to new ones. Talk to Gadget and see if he can get you the AFE headers.
  9. Redlantern
    Redlantern Member
    Jan 28, 2013
    525
    6
    Level Ten Carries a DIY kit and is much friendlier on the wallet.
    http://www.levelten.com/750E_F_VALVE_BODY_KIT_p/toy-ja210-5000sk.htm
    A member here named iniazy did it for someones Prado. Here is his writeup on it.
    http://www.xr-underground.com/forum/showthread.php?t=56514
    I say do this first since you're already boosted. It'll save the life of your transmission.
  10. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Thanks for the tip, i may look into those depending on how much suffering i may have to go through with the emissions. I know i can get away with removing the front cats if i have the 02 sim, but if i get the y pipe later on i wont pass the visual inspection. Then again the y pipe is a relativly easy swap back and forth.
    Do you happen to have a link to any dyno information for these babies?
    Keep the good ideas coming, i have about 2-3 weeks before i make a firm decision. I probably should have set up a poll for this thread, but ive never done it.
    #10 woodex m.e., Dec 20, 2015
  11. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    This is exactly what i was looking for! And since the price is that reasonable im really thinking about doing it at the same time as the next mod.
    So it seems like the best gains i can get are with a set of headers (and the level ten upgrade of course) im really horney over the fact Gadget has the dyno chart for just the URD equal lengths. If anyone else has data to go with their suggestion i would love to see it.
  12. justin13703
    Sep 9, 2010
    2,766
    14
    Yeah I figured it would be a stretch but I just wanted to mention it anyway.
  13. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Hey you never know, sometimes what seems off the wall Is the way someone goes. I appreciate the input.
  14. XMPLRY808
    XMPLRY808 Active Member
    Dec 5, 2014
    402
    74
    Headers, y pipe and a tune I like the maf cal idk how much more you would gain with the ucon over the maf cal considering the price difference...
  15. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,965
    70
    Not a "power mod," but I don't see a short-shift kit on your list...
  16. thewarriordinghy
    Apr 9, 2015
    582
    11
    You can run catless and pass visual...u just need an exhaust shop to make you a fake bolt on cat or two, put them on for visual and pass.... I have a friend in the system, and he says people do it all the time.
  17. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Yes I am curious the difference I could see. It would make me feel better putting in bigger injectors and having them controlled properly to compensate for the weather around here.
    #17 woodex m.e., Dec 25, 2015
  18. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Haha if I had a 6 speed I would have already done that, but I'm an auto. I'm one of them moochers that flowed over from Tacoma world over to here. The speed knowledge here seems to be more plentiful.
  19. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Yeah that's what the local shop told me to do if I wanted to eek by. But for now I'll still have the rear cats. I just pulled the trigger on the spec u headers about 10 min ago. I'm already feeling guilty. I hope I can actually notice the power difference. According tothe Dyno evidence it should be obvious and feelable. I hhope so.
  20. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Urd spec u headers installed. And i love them. Now time to build a house, no More power for a while probably :(
