Where does this washer go? In the middle of TRD SC install
Discussion in 'F/I Mods & Tuning' started by Wizard, Jun 1, 2017.
  1. Wizard
    Wizard Member
    Dec 11, 2008
    310
    Boosted brothers,
    Any one know where this washer goes? Diameter is roughly 1.25" . I'm probably about half way through the TRD SC install on my 2006 Xrunner. The only place that makes sense for this washer is on the backside of Idler No. 1 (the one at the bottom that we have to tinker with) based on the bearing/rubber configuration and how it's very different than idler no. 2. I've been very careful up to this point, and never heard this washer hit the ground as I removed both of the idler pulleys. I found this washer when I climbed under the truck recently to tighten the radiator drain valve. Any help would be most appreciated or scanned pages of the Factory Service Manual.
    Note: This washer is not the same as the two thin washers portrayed in the following diagram. I have the thin step washers and confirmed they were re-installed per the diagram. Plus, these two thin washers are a bit different from the washer that I posted a picture of in that the center portions of the thin washers are raised ever so slightly, hence the name 'step washers'. The diagram makes no mention of the flat washer in question, so I don't want to install it if it's not required.
    #1 Wizard, Jun 1, 2017
  2. NHXRUNNER
    7,663
    185
    Pretty sure that's the "thin step washer" they speak of in the "NOTE". My truck didn't have those washers. But I'm not sure if it goes step washer, then pulley or pulley then step washer.....
  3. 30Birdy
    30Birdy Member
    May 3, 2015
    246
    14
    It's been 2 years since I did my install. Not sure I recognize it.
  4. o0opackersfano0o
    Jun 23, 2016
    389
    82
    The washers in the manual have a step on them. I'm heading out to the garage in a minute I'll look through supercharger instructions.
  5. o0opackersfano0o
    Jun 23, 2016
    389
    82
    Ya I don't see anything and doesn't look familiar to me. Spare parts. Lol
  6. NHXRUNNER
    7,663
    185
    It's not a part from the kit, it's a washer that's either in front or behind the stock pulley on some trucks.
  7. Wizard
    Wizard Member
    Dec 11, 2008
    310
    I've been told the Factory Service Manuals are discontinued. Anyone kind enough to share PDFs of the manuals so I can continue to research this mystery washer? Thanks.
  8. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,901
    40
    Here you go:
    Repair Manual:
    http://www.customtacos.com/tech.old/files/05FSM/repair.html
    Wiring Manual:
    http://www.customtacos.com/tech.old/files/05FSM/wiring.html
    Good luck!
    Edit:
    What about the washer for the stock idler pully?
    See page EM-88:
    http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/00700810.pdf
    Each idler pully has one. I can't tell the size and I don't have my X anymore to visually check.
    As your instructions say, some trucks may not have the thin step washer.
    Your's probably just came with a regular washer.
    #8 BSP06XRU, Jun 2, 2017
  9. whippersnapper02
    Nov 16, 2010
    394
    18
    The blower install manuals says Idler #1 (between the crank pulley and ac compressor) may have a "thin step washer" but it doesn't give a thickness.
  10. Wizard
    Wizard Member
    Dec 11, 2008
    310
    Thanks guys, but as I stated before, ". I have the thin step washers and confirmed they were re-installed per the diagram. Plus, these two thin washers are a bit different from the washer that I posted a picture of in that the center portions of the thin washers are raised ever so slightly, hence the name 'step washers'."
    The flat washer that I posted a picture of would be a third washer.....
  11. whippersnapper02
    Nov 16, 2010
    394
    18
    Ok I think I see it. It shows one 20mm washer in the kit. Washer A7. It's for the tranny cooler which you wouldn't have if you have a X.
    #11 whippersnapper02, Jun 2, 2017
  12. whippersnapper02
    Nov 16, 2010
    394
    18
  13. whippersnapper02
    Nov 16, 2010
    394
    18
  14. o0opackersfano0o
    Jun 23, 2016
    389
    82
    that washer is too small I had that left over on mine and it fits a 10mm bolt.
  15. NHXRUNNER
    7,663
    185
    Good point....1.25" is roughly 32mm
