Which Clutch to buy?
Discussion in 'N/A Mods & Tuning' started by gsxrdoug, Feb 4, 2012.
  1. gsxrdoug
    gsxrdoug Member
    Dec 28, 2010
    371
    Ok, 2007 X with 70k on it. Looking at getting a new clutch, however not sure which one!
    I don't drift, don't drag, do flog it every once in awhile, so competition is not nesesary.
    Stock engine. No plan on boosting or Turboing. A daily driver as well.
    Advice?
  2. GrumpyOldMan
    GrumpyOldMan Member
    Feb 10, 2007
    562
    Stock clutch/pressure plate and URD's fix for chattering clutches.
    If you don't get URD's kit make sure to replace that TOB while ya got it apart...
    OH, and feel free to PM me a link to the rest of the photos from your Avatar LOL
    Dave in Dusty Doha, Qatar
    Deployed Gov't Contractor in need of some Alcohol Abuse LOL
  3. gsxrdoug
    gsxrdoug Member
    Dec 28, 2010
    371
    Grumpy I'll have a beer for ya before I get on the Plane, flying back to Cali today. I plan on doing the TOB fix from URD, gotta do that. At least will be saving money on the stock stuff. I wish I had the rest of that photo. :biggrin:
    Has anyone tried Exedy OEM part #TYK1503 it's a little less than 300. Not sure if I should go with direct replacement from Toyota or an aftermarket OEM type?
    #3 gsxrdoug, Feb 4, 2012
  4. Gadget
    10,902
    149
    The Stage 3 Clutch we have is the best all around clutch. It is great for both boosted and N/A applications.
  5. gsxrdoug
    gsxrdoug Member
    Dec 28, 2010
    371
    Stage 3? really I thought that was a little jumpy for N/A trucks?
  6. Slywhitty
    Slywhitty "Midget Magnet"
    Jan 26, 2008
    3,393
    Ive been running a Stage3 with the lightweight flywheel from Urd since may. Takes a little getting used to but after a while it becomes just like driving a stock one. Def your best choice and if your plans change (aka boost or anything else) it will still hold the power!!
  7. dramad1
    dramad1 Active Member
    Mar 27, 2010
    2,367
    I vote spec2+ clutch. Since your n/a and only punch it now and then.
  8. 05 TwinSnail-XR
    05 TwinSnail-XR New Member
    Nov 2, 2011
    33
    Look into Fidanza flywheel and spec 2+ clutch combo. kinda pricey but worth every penny. Thats what im putting on my Twin turbo XR.
  9. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,766
    14
    ^ What he said. Ive had my Stage 3 clutch and lightweight flywheel from URD for about a year and I love it. It takes a little getting used to because it obviously grabs alot better than stock but once its broken in there isnt any shuttering or anything. I love it and even though I'm boosted it would still be a great one for an n/a truck.
  10. MonteSS8707
    MonteSS8707 New Member
    Aug 29, 2011
    132
    I have yet to install my CC Stage 3 clutch, but I plan on staying n/a and thats what I went with. Seems that a lot of ppl on here run that one.
  11. 05 TwinSnail-XR
    Nov 2, 2011
    33
    Yea but a plus side to the fidanza flywheel is that you can change the pads for cheap making it the last flywheel you will ever need.
  12. hottacoX
    hottacoX Moderator
    Dec 21, 2009
    4,823
    For a DD truck I wouldn't go with a fidanza fly. Yes the friction pad can be replaced but you have to replace it before it wears too far and literally grinds off the heads of the bolts....
    Plus with the fidanza, not that it will happen but more hardware attached to it leaves more room for failures....
    An upgraded steel fly will give ya enough pickup/response for a dd
    also with those twin snails I would imagine a stage 2+ would still have a lot of slip, why not 3+ or even 4.....
  13. X-Runnin
    X-Runnin New Member
    Feb 5, 2007
    988
  14. gsxrdoug
    gsxrdoug Member
    Dec 28, 2010
    371
    Anyone used this one yet, I know there are alot of you guys out there.
  15. X-Runnin
    X-Runnin New Member
    Feb 5, 2007
    988
    I guess I might have to be the guinea pig on this one
  16. TahoesHateMe
    TahoesHateMe New Member
    Mar 11, 2007
    1,115
    I need to replace my clutch also. Haven't decided which one yet.
  17. hottacoX
    hottacoX Moderator
    Dec 21, 2009
    4,823
    From what I have heard exedy is an ok oem replacement in general but for out application haven't heard anyone that ran it...
  18. 05 TwinSnail-XR
    Nov 2, 2011
    33
    Ive never heard of a Fidanza wheel ever failing. And as far as a spec 2+ and not higher is cause iI still tow with my truck and cause the wife still jumps in it every once in a while. I just put the fidanza and spes 2+ in this weekend at my job and it feels great. Havnt riped into her yet still waiting for breakin. And an other thing is that the stock flywheel and clutch that came out did not look bad at all for being under boost for almost 5 years and 44k now.
  19. TahoesHateMe
    Mar 11, 2007
    1,115
    My clutch flat out died. I'm hoping my flywheel isn't damaged. I'm just going to keep it stock. As much as I want a lightened flywheel I actually use my truck as a truck and the stock flywheel will be better for towing and hauling bikes.
  20. gsxrdoug
    gsxrdoug Member
    Dec 28, 2010
    371
    Tahoe I'm in your shoes I tote my bikes around and like the fact there is some low end grunt and really don't want to worry about changing to much that will require attention in the long run, just wondering if OEM or OEM copy would work for daily. I'm sure OEM is not cheap either.
