Will Lexus IS 350 rims fit on Xrunner?
Debo
Will the Lexus IS 350 wheels fit on my Xrunner? I understand the bolt pattern is the same,
But the center of the wheel of the Lexus might need to be bored out.
Just weighing my options.
Thanks!
hrspwr236
I believe you will be okay with the center bore last I checked, but the width and offset will be make the wheels sit further inside the wheel wells, it will look bad unless you plan on tucking those wheels with a bagged set up. If your looking into changed up your wheels but trying to stay cheap with used oe wheels off craigslist, look for some 350z or g35 wheels it will have similar offset to the X-Runner stock wheels!
kwigs160966
I have nismo lmgt4 on my x off a 305z they fit nicely. They have a bigger hub than the x but I don't run any hub rings.
hrspwr236
As long as your not running spacers you won't need hubcentric rings.
Debo
Is the width of the Lexus 250 rim deifferent
From the oem Xrunner wheels?
hrspwr236
Is wheels are 18x8 ET 45 front and 18x8.5 ET 50 rear
X-runner wheels 18x8 ET 30 both f/r
You want a lower ET (offset)
Put in perspective, Ihave 20x10 ET 25, the wider the wheel and lower the offset will flush you out better with the fender flares :top:
