Write Up: 2012+ TRD CAI
Discussion in 'How-To' started by 05TACOMAXRUNNER, Mar 27, 2015.
  1. 05TACOMAXRUNNER
    Jan 22, 2007
    52
    I had the original GEN I TRD CAI in my 2005 and I am now modifying it to install in my 2013 with a few extras.
    The parts I am using are as follows:
    GEN I TRD CAI P/N PTR03-35090
    afePower Housing P/N 05-82342B2 (This is necessary over the housing that came with the TRD CAI as in 2012+ the A/C lines are in a slightly different location in the engine bay and the afePower housing has a big indent in the underside of the housing that the TRD housing from the earlier years does not)
    afePower Relocation Bracket P/N 05-12332B4
    afePower Harness P/N 05-01266
    afePower Head Screws P/N 03-50106 (x2)
    afePower Fender Washer P/N 03-50070 (x2)
    afePower Hex Nylon Nut P/N 03-50073 (x2)
    Volant Ram Air Scoop P/N 38640
    Silicone Intakes 4-1/2" to 4" Hump Hose Coupler (Red)
    Silicone Intakes 3" to 3" Hose Coupler (Red)
    Silicone Intakes 3-1/2" to 3-1/2" Hose Coupler (Red)
    As most people know, the 2012+ Tacoma contains a smog pump in the emissions systems that pumps air into the exhaust manifolds which wasnt present on the earlier years, so therefore the Gen I TRD CAI is not applicable. With a few parts from afePower's 2012+ CAI, I am able to install the Gen I TRD CAI in my 2013. Yes I could just buy the proper afePower CAI for the 2012+ Tacomas but I had the TRD CAI sitting around from my 2005 and did not want to buy the complete afePower CAI. So while I was going through the process of modding the TRD CAI, I decided to add the Ram Air Scoop from the Volant CAI system. The TRD CAI originally came with the red rubber couplers and the Volant Ram Air Scoop comes with a black hose coupler, so I decided to replace all the couplers with red silicone couplers that I picked up from siliconeintakes.com for a very reasonable price.
    So first thing I started with was how I was going to tie the Volant Ram Air Scoop into the TRD CAI. I know it has been done on here before but the is how I decided to go with this. The Volant scoop comes with a 3-1/2" I.D. coupler. I took a trip over to home depot and was able to pickup a 3-1/2" O.D. closet flange made of PVC. The closet flange of that size was only available in white, but I will deal with that later. So I took the closet flange and cut it to fit where i could mount it to the TRD CAI where it would look as if it came with it when I was finished. I also cut a gasket out of some black gasket material so I could ensure a proper seal when it was seated into the housing. The location was close to the edge of the housing so one side of the closet flange had to be cut flat to fit properly.
    Once the closet flange was cut and would fit it was time to drill the hole. I used a 3-1/2" hole saw and measured the location with the TRD CAI housing and Volant scoop mounted in place in the engine compartment. In order to attach the closet flange into the CAI housing I drilled 3 holes in the lip of the flange and used 3 allen head screws that were similar to the 3 allen head screws used to mount the filter adapter into the CAI housing. This ensured that the closet flange would look like it belonged to the GEN I TRD CAI originally. After everything was checked and lined up properly I grabbed some 220 grit sant paper and sanded the entire PVC closet flange and spray painted it flat black to match the CAI housing.
    After all said and done with the prep work the new flange for the Volant scoop coupler is installed and doesnt even look like I modified and added it to the TRD CAI.
    After I was finished modding for the Volant scoop, I mounted the smog pump relocation bracket I got from afePower to the CAI housing using the supplied hardware.
    After mounting the relocation bracket, everything was ready to be installed into the truck. Everything gets installed and mounted as it did in the instructions for the Gen I TRD CAI. In order to mount the Volant scoop, all that is required is to remove the plastic push clips on the plastic radiator shroud cover and the shroud cover itself. Then save 3 of the clips to reuse to mount the Volant scoop on the center 3 holes towards the front of the vehicle from the removed radiator shroud plastic cover. The only thing left to do is install the smog pump wire harness extension from afePower from the factory harness to the smog pump after it is installed into the relocation bracket on the side of the CAI filter housing.
    This is the Gen I TRD CAI all modded and installed into my 2013.
    Air filter housing cover was off in the final picture for cleaning and oiling. Will be back installed tomorrow and ready for a test drive. :top:
  2. MrX-runner
    MrX-runner Member
    Sep 4, 2013
    309
    6
    Nice, write-up. I have a similar set up, AFE CAI with Volant Ram Air Scoop.
  3. hrspwr236
    hrspwr236 Active Member
    Jul 2, 2007
    8,886
    Nice job, I took the easy way out and bought the Volant with scoop and honestly would have another tacoma with out it!
  4. Torspd
    47
    Nicely done. :top: 2013 with a Gen 1 intake modded to fit a smog pump. I like.
  5. Superloki24
    Superloki24 Member
    Oct 24, 2009
    215
    21
    This is pretty much exactly what I am going to be doing. I'm picking up my old TRD Gen 1 CAI next week and will be ordering up the extra parts from aFe sometime in the near future.
    Good write up though.
  6. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,914
    48
    Very clean install! :top:
  7. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    Nice write up.
    This would finish it off nicely.
    Yes, it was a shameful thread jack.
  8. 05TACOMAXRUNNER
    Jan 22, 2007
    52
    Yes it would!! How much coupe?
  9. hrspwr236
    Jul 2, 2007
    8,886
    Agreed, must have, end thread jack!
  10. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    Normally it is $150, but it is on sale until 4/15. Price on sale is $125 shipped.
