Write-Up: Black Headlight Mod
Discussion in 'How-To' started by Stevenredx, Jan 15, 2007.
  1. babyboi2284
    babyboi2284 BaggedXR2284
    May 23, 2010
    3,968
    Why are you trying to remove the reflector bowl? Those are two adjustment screws. You have to keep unscrewing them to take the bowl off but you don't have to take it off for the BHLM.
  2. GillMAN
    GillMAN New Member
    Sep 14, 2011
    55
    I havent purchased the retro fit lights yet but i purchased this set of OEM lights to prepare for the mod. I am just doing the BHLM for now. So this does help!!! thankyou
    update: i just purchased a set of DTLTH on ebay for $456 brand new in the box!!! it was to good of a deal to pass so i will not have the Retro Fit Source for a while now...
  3. RRCanuck
    RRCanuck New Member
    Sep 13, 2010
    1,057
    Thats the way to do it! I went with all breather mods first. Ive got thousands and thousands into her now and you can hardly even tell haha.
  4. GillMAN
    GillMAN New Member
    Sep 14, 2011
    55
    bet you can when you hit the gas :blurock:
  5. xrunnerjoe89
    xrunnerjoe89 New Member
    Oct 3, 2007
    532
    Just took apart my first headlight, Damn that crap was hard. took me 4 different tries..lol. Im hopin this second one works out easier. Definetly easier when i used 310 for 11 minutes.
    Update: I just finished taking headlight #2 apart and did it on first try :). Seems pretty easy if u follow directions and take your time. 310 for 11 minutes seems to be the lucky winner for heat and time. I probably wont get around to painting them for a couple days, but will post pics when done.
    #165 xrunnerjoe89, Oct 7, 2011
  6. JDUB916
    JDUB916 Guest
    Quick question. I guess its my time to take a stab at this. I have eyelids on my headlights, is it safe to put it in the oven or do I need to pry the 3M tape off? Im assuming itll be okay? I read someone else posted this question, but no one really answered it.
    Also, it sounds like Satin paint is the best type? I have a SWB XR and I want it to look good with my HID's. I plan on doing this tomorrow so your help is greatly appreciated.
  7. babyboi2284
    May 23, 2010
    3,968
    Yes you can put them in the oven with the eyelids on. I did mine and had no problems at all.
  8. JDUB916
    JDUB916 Guest
    Thanks! So what paint did you use? Krylon Fusion Satin? I think that's what I will use as well. And any Clear WIndow/Door Silicone like the kind you get at a hardware store? Like the kind in the long white tube?
  9. babyboi2284
    May 23, 2010
    3,968
    Yep krylon fusion satin black. No I didn't use that kind of silicone. I used clear window silicone in a small clear tube from wal mart for the first two times I took my headlights apart. But when I just put my projectors in I used the grey factory type adhesive that came in my kit.
  10. JDUB916
    JDUB916 Guest
    Cool I'm ready to go first thing in the morning! Thanks for the quick reply I was at wal-mart when u did it. Pics tomorrow
  11. babyboi2284
    May 23, 2010
    3,968
    No prob bro good luck. Make sure to put the lights on the lowest rack in the oven so they don't accidentally touch the oven roof when you put them in...been there lol. And make sure to turn the oven off after you put them in. I've heard of the lenses glazing over from the heat being left on by mistake.
  12. JDUB916
    JDUB916 Guest
    Quick question before I get started. Once I'm done painting, do I put the painted piece back in the housing and then the clear lense on it as well and then bake it again for 5 mins? I was confused cuz it says to put the two pieces back in the oven, is t that 3 pieces? Or is it that I install the black painted piece into the housing and put that in the oven with the clear lense as well separately and once heated then press them together?
  13. babyboi2284
    May 23, 2010
    3,968
    Put all three pieces back in. Be careful when putting the painted piece back on the lens so you dont chip the paint but it may happen anyway due to the tight fit. Put the two screws back into the back of the painted piece, put a bead of silicone in the channel on the grey part then press together and put in the oven. Just make sure not to put any of the plastic pieces on back of the headlight or the bulb until you take them back out.
  14. JDUB916
    JDUB916 Guest
    All 3 pieces back in assembled and bake it again as a whole headlight?
  15. babyboi2284
    May 23, 2010
    3,968
    Yep bake as a whole headlight
  16. JDUB916
    JDUB916 Guest
    Ok thank u do much bout to start
  17. elynor_v
    elynor_v New Member
    Feb 8, 2010
    396
    Don't touch the inside of the lens or you'll end up with fingers prints you can't wipe off without taking the whole thing apart again! :bawling:
  18. JDUB916
    JDUB916 Guest
    All done! Thanks guy!!! That wasn't hard at all. First light was hard to get apart but 2nd light I did it for 1 min more an it came apart easy! Found it easier to get bottom bolt off from the side of the wheel well. I gouged one my eyelids tho so I'm gonna have to touch that up but all in all I don't know why I waited 5 years to do it! Lol
    Thanks for the quick replies yesterday and today bruthas! Pics to come after a smoke and a shower :top:
  19. shaggy08xr
    shaggy08xr Active Member
    Sep 25, 2009
    2,239
    This is one mod I have been wanting to do for as long as I can remember, but I just don't have the balls to cook my headlights. Im worried ill screw something up. Glad it went ok for you and can't wait to see the pics.
  20. JDUB916
    JDUB916 Guest
    I love to mod stuff, but I felt the same way, i was totally scared about doing it. But if you just follow the directions, you really cant go wrong. Take your time, and dont rush, and youll be just fine. Give it a shot bro!
    Here's the pics, what I guys think?
    #180 JDUB916, Oct 22, 2011
