Write-Up: Coupe's Shifter Mod
Discussion in 'How-To' started by Coupe, Oct 12, 2009.
  1. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    The harder the epoxy, the firmer the shifts. I will say you hardly notice the difference between 45 & 90. There is a difference, but in my opinion, not worth the noise. (Yeah, I am getting old).
    The noise may happen during shifting, but will also happen while in gear, mainly during hard acceleration. This is the case for the harder epoxy.
  2. revobreaker
    revobreaker Moderator
    Nov 8, 2007
    3,138
    10
    The one I have now I notice the noise while changing gears. I only notice noise in gear if I leave my hand on the sifter and get "heavy handed" or apply some pressure.
    Id be willing to try it out
  3. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    That is about the same with mine. A little noise when making the shift.
  4. AFP520
    AFP520 New Member
    Sep 19, 2007
    829
    I kinda like the fact I have no bushing or epoxy to worry about. The noise isn't really all that bad and I kinda like hearing the whining while I'm gettin on it. Call me crazy :biggrin:
  5. AlexForbesR6
    AlexForbesR6 New Member
    Nov 5, 2009
    66
    hey coupe! i saw this link posted up on Tacoma World (thats my home :D) and i have been debating on which direction to go for a while and finally decided to get one of yours!! i live in the houston area also so if you want you can pm how much it would cost me to give you my stocker and get one of these bad boys in a 9in length in exchange.
  6. SX TOY
    SX TOY Active Member
    May 23, 2009
    1,965
    the noise increases when you get a lightened flywheel. I have a B&M and am currently doing the coupe mod to my stock shifter assembly to be used with a URD ss plate.
  7. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    PM sent........
  8. rice247
    rice247 New Member
    Mar 24, 2009
    541
    Hey Coupe, you still have any more you want to let go? If so how much? Shipping to 92126
  9. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    This go for $120 exchanged. This includes shipping and a new tip bushing.
    If you want one pm, me.
  10. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    I have received a few more cores lately, including TRD cores.
    If anyone has been wanting one of these, this is a good time to get one.
  11. LateOnTheBrakes
    Aug 2, 2009
    310
    What is the point of the 1/4" cap screws you install after the epoxy cures? I understand the long ones are to hold the center shaft. But if the smaller bolts don't make contact with the inner shaft what purpose do they serve?
  12. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    When allowing the epoxy to cure, you want long bolts to hold everything together. After the epoxy is cured, I pull the long bolts out and epoxy small bolts in place. The small bolts so not contact the inner rod. I do not want the long bolts touching the inner rod, because it will transmit noise.
    These short bolts get a bite into the epoxy and resist a twisting motion. Without them, it is possible to twist the outer shaft off of the epoxy. Let's say if you got a little rough with the shifter when installing a new shift ball. Yes it has happened.
    By the way, I have some of these made up, if anyone needs one.
  13. LateOnTheBrakes
    Aug 2, 2009
    310
    I see. The shorter bolts are sheer pins to prevent rotation of the outer shaft with respect to the epoxy "bushing" and the hose clamps provide surface area to prevent rotation of the epoxy bushing to the inner shaft?
  14. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    Bingo.
    I have stopped doing the hose clamps. I now cut grooves that run long way on the inner rod. The epoxy fills in those grooves and gets a bite on the inner rod.
  15. faulkdizzle
    faulkdizzle New Member
    Aug 29, 2010
    148
    i know this is an old thread... im gonna be doing this mod but want to keep my stok shifter heighth.... could i just pry out that bushing or will i still need to cut it off???
  16. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    If you add a URD or NST SS, it raises the height 3/4". I could minimize the cut down. so it would work out the stock height.
  17. aloe
    aloe New Member
    Apr 19, 2009
    71
    might have to get one of these in the 8 1/2" length!!!
  18. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    Yes. I have them in 8 1/2" length.
  19. kelson
    kelson New Member
    Nov 5, 2008
    588
    do you think it would be possible to pull of this mod for a 5-speed? my shifter sits WAY to high now with my new seats, and it's a little irritating. from looking at the pictures, it looks pretty similar to mine.
  20. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    13
    I would say it is possible.
