Write-Up: Fog Light Mod (always on)
Discussion in 'How-To' started by K2, Jan 13, 2007.
  1. Dewey7
    Dewey7 Member
    Jul 19, 2012
    Thanks for the write up I went with option 1. When I was finished everything looked awesome. Worked perfectly. But when I started my truck up it was idleing at 300-400 rpm. I was freaking out did I do something wrong. I searched this forum and found a few guys saying the truck needed to re-learn its idle. Sure enough couple runs later back to norm. Thanks everyone.
    :rockon:
  2. -kenny-
    -kenny- New Member
    Jul 1, 2013
    32
    stopped by Pepboys and got everything i needed. i followed the steps. easy as cake.
    it worked the first try. took 10mins to get all the wires connected, heat shrank and put all the fuses in. then another 5mins to put it on the X. worth the money and easy mod
  3. hrspwr236
    hrspwr236 Active Member
    Jul 2, 2007
    8,886
    Did option three like I did on my 06 and didn't work on my 2012? What the deal, anyone else have a problem with the newer Xs the fogs still works just like factory?
  4. sanchleo
    sanchleo New Member
    Oct 12, 2012
    35
    i like this mod alot
  5. uno808
    uno808 New Member
    Nov 16, 2013
    39
    thanks for the write up! super easy to follow
  6. specless
    specless New Member
    Mar 16, 2014
    32
    nice write up
  7. X-Runn-it-09
    X-Runn-it-09 New Member
    Jun 14, 2014
    I did the option and now i have no abs and tcs is off..i camt figure it out
  8. X-Runn-it-09
    Jun 14, 2014
    I did opt 1 and now my TRAC and ABS lights are on then the engine jumped down to 3-400 Roma but kicked back up after my ECU relearned the system but I can't get my lights to shut off any advice. :hmmmm2:
  9. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,753
    9
    If yours is an 09 then the write up might not apply to you. A lot of stuff changed on the 09 and up so that might be your problem. Whatever happened sounds bad so I would undo it ASAP and try to find a write up for an 09
  10. X-Runn-it-09
    Jun 14, 2014
    Yea that's what I'm gonna do cause ECU keeps having to relearn evrerything.....so sad cause it looks good
  11. hrspwr236
    Jul 2, 2007
    8,886
    The add a circuit is the easiest way for this mod!
  12. nolove
    nolove New Member
    Dec 23, 2013
    30
    Thanks for the detailed write up. Next on my list.
  13. Hi_Psi
    Hi_Psi New Member
    Sep 4, 2014
    42
    Best....... Mod........ EVER!!!!! Lol took literally two min. You dont need the extra piece of wire, the Add-a-Circuit i got had a long wire strand, just needed to cut off the connector on it and install a new end for the fuse. Didnt find a 5amp fuse so i went with a 4amp. Should work fine.
