Write-Up: Modifying Front Core Support Brace (behind grill)
Discussion in 'How-To' started by Tapp, Sep 2, 2008.
  1. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    hey guys, i have received a few pm's on how i did this and after getting one from 06XR-SW, i finally got off my lazy arse and took some more pics for this write up!!
    This core support brace is for the TRD S/C owners.. i havent looked at a N/A one yet to see how much of a difference it is..
    BEFORE:
    (viewing VabchXrunner's Core Support)
    AFTER:
    (viewing mine)
    TOOLS NEEDED:
    - phillips head screw driver
    -10mm rachet
    -hacksaw
    -8mm rachet
    -duplicolor anti-rust flat black
    -50 grit sandpaper/or metal file
    (going by memory, its quite easy)
    STEP A:
    - remove your grille
    -now remove your latch cover, the latch itself, and the core support (all use 10mm)
    STEP B:
    -now look at the bottom of your core support there are 3 (10mm) bolts holding your water pump...remove them
    -there should be 2 more bolts remaing (8MM) if i'm correct that lead out to the bumper (you cant miss it)
    one is visible and the other is tucked under the bumper...remove them as well
    Now that you have the core support off the truck! you will see 2 welds..Look at the pics below to know where to cut..
    STEP C:
    now cut, using your hacksaw just below the weld on the upper portion of the core support, and just above the weld on the lower portion...
    [​IMG][​IMG]
    STEP D:
    -once you are satisfied with your cuts, you 50 grit sandpaper, or a metal file. Just to make it smooth
    - and to prevent rust! Spray some Duplicolor anti-rust on..let dry..
    The end result should look like this...
    I have had no issues with lack of support at the latch or with the water pump..have had this done for a few months now!!!:rockon:
  2. Stevenredx
    Stevenredx New Member
    Looks good, nice work bro :top:
  3. T0LLPHR33
    T0LLPHR33 "Catwoman"
    Jun 17, 2008
    10,969
    Tapp: nice write up and pics to help follow along...:top:where did you get the TRD radiator from?
  4. trd_sport
    trd_sport Active Member
    Feb 18, 2007
    6,563
    I dont get it:dontknow::questionmark:
  5. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    the TRD on the heat exchanger, is something i did myself...
    all your doing is removing that vertical bar...too me it was an eye sore, so i removed it...
    you cant really see it with the stock grille..but since im recessed...it had to go!!!
    to me it just runs smooth without it..
    #5 Tapp, Sep 2, 2008
  6. trd_sport
    Feb 18, 2007
    6,563
    ^ Ok now I get it!!!!! lol.
  7. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    :rolleyez: There ya go buddy!!!
  8. T0LLPHR33
    Jun 17, 2008
    10,969
    that heat exchanger with the TRD(in Red) is sick bro...:top: when I get the fundage for a T/T setup I might have to copy you...LOL:top:
  9. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    its all good!! I saw SHOOK have it and i wanted to do that as well...
  10. brokenvendetta
    brokenvendetta New Member
    2,574
    nooooob :laugh:
  11. T0LLPHR33
    Jun 17, 2008
    10,969
    I like how you were able to fit the heat exchanger with the recessed mod grille. very clean :biggrin: I'm trying to save money for my T/T setup...so hard when all these awesome parts and deals keep coming out...:laugh: I was thinking of doing a air/air intercooler like the WRX/STI have...make use of that hood scoop:
    Top-Mounted Intercooler:
    Tapp: if it fits i will do this type of setup...if so I will paint the radiator black and do the TRD (in red like you did) hopefully with everything black w/recessed grill and red TRD letter hopefully the TRD pops out nicely...just an idea for now
  12. 06XR-SW
    06XR-SW New Member
    Sep 12, 2007
    2,313
    Thanks TAPP looking GOOD!!! nice write up now i all i need is a s/c!!!
  13. AirborneXR07
    AirborneXR07 New Member
    Oct 8, 2008
    60
    does the trd supercharger come with the heat exchanger??
  14. KETCHUP
    KETCHUP Active Member
    Nov 1, 2007
    11,665
    nice WU bro!!!
    looks good.
  15. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    hey tapp, im na but i did this (it all looks the same by the way) and was just wondering if you had any problems with the hood not latching right and when you drive down the road does the hood look like its moving up and down, cause mine does and its driving me crazy
  16. blastap
    blastap New Member
    May 20, 2007
    4,247
    yes my hood moves so i made some different mounting brackets to fix all that
  17. lamecargo
    lamecargo Active Member
    Sep 15, 2007
    1,306
    i did this and my hood moved like crazy too so i installed hood pins
  18. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    im not to worried about the hood moving , its just try'n to close the dang thing,
    what kind of brackets did you use blastap? just like some L brackets or somthing, cause i just got done with the RGM and it looks awesome w/o that brace and id hate to go and have to get a new one.
    Thanks
  19. NixXR462
    NixXR462 New Member
    Mar 22, 2008
    2,630
    Thats cool do all that modding and not take pics. You should be banned
  20. X'ED
    X'ED New Member
    Oct 9, 2007
    618
    i took pics my stupid computer has been retarted and wouldnt let me upload pics ...
