Write-Up: Reset Maintenance Indicator
Discussion in 'How-To' started by Stevenredx, Jan 29, 2007.
  1. Stevenredx
    Stevenredx New Member
    Reset Maintenance Indicator (05+)
    Source: customtacos.com
    By: Wepps03Coma
    This is directly from the owners manual Section 1-6 "Operation of the Instruments and Controls" under "Service reminder indicators and warning buzzers" Subsection G "Engine Oil Replacement Reminder Light" page 150
    Clearing the "Maint Reqd" light on 2005 and up Tacoma's
    This light acts as a reminder to replace the engine oil.
    This light will come on when the ignition key is turned to "ON" and will go off after about a few seconds.
    When you drive for about 7200 km (4500 miles) after the engine oil replacement this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key turned to the "ON" position. If you continue driving without replacing the engine oil, and if the distance driven exceeds 8000 km (5000 miles), the light will come on after the ignition key is turned to the "ON" position. The light will remain on thereafter.
    If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. IF the light comes on, replace it as soon as possible.
    The system must be reset after the engine oil replacement. Reset the system by the following procedure.
    1. Turn the ignition key to the "OFF" position with the odometer reading shown
    2. Turn the ignition key to the "ON" position while holding down the trip meter knob.
    Hold the knob for at least 5 seconds. The odometer indicates "000000" and the light goes off.
    If the system fails to reset, the light will continue flashing.
    #1 Stevenredx, Jan 29, 2007
  2. project-c2
    project-c2 New Member
    Feb 27, 2007
    1,880
    Good thing I used the search button and found this. My light just came on. I tried it, but didn't set it to odometer reading. I'll try again. I love XR-U:top:
  3. i_ski
    i_ski New Member
    Apr 4, 2007
    1,041
    I betcha there's a way to check trouble codes through the odometer. I know I could do it on the Grand cherokee I used to have. If only we could find out how.
  4. AFP520
    AFP520 New Member
    Sep 19, 2007
    829
    That's the check engine light, not maintenance required light. This is for oil changes only. It comes on every 5K.
  5. carolinyens
    carolinyens New Member
    Apr 8, 2008
    Mine just came on but I dont wanna clear out the mileage. Will this still work if i turn it to trip A or B?
  6. TitanRattler813
    TitanRattler813 Active Member
    Feb 28, 2007
    7,641
    20
    Not quite sure what you're getting at :hmmmm2: ... It's not gonna reset the total mileage on your truck. I just makes the Maintenance light go away.
    What mileage do you not want to clear? :dontknow:
  7. carolinyens
    Apr 8, 2008
    Well theres the overall mileage which is what comes up when on But if you just press the switch it goes to trip A then to trip B. I was just wonderin if this will clear out my overall mileage.
  8. speed_raca7
    speed_raca7 New Member
    May 16, 2008
    162
    if ur asking if it would reset ur total miles driven, no it wont. before you turn the truck key to off make sure you have it set to odometer. hold the trip button and turn key on and continue to hold till the gauge does its thing. then ur set :top:no more maintenace light
    im not sure if it will reset ur trip tho.. sorry
  9. carolinyens
    Apr 8, 2008
    ok thx for the answer. Thats what I was tryin to say. Its always easier to show than it is to say.
  10. Talerra
    Talerra New Member
    Dec 1, 2008
    282
    my light just came on too good going guys! thank you
  11. Ghost05X
    Ghost05X Member
    Jun 10, 2009
    67
    Yeah my light just started coming on and i was getting worried. But i found this info and got it fixed. Thanks!
  12. deanbhula1
    deanbhula1 New Member
    Jun 2, 2009
    213
    good to know
  13. Liquid-X
    Liquid-X Banned
    Jun 14, 2009
    67
    Crazy it was something this simple.
  14. amallgood
    amallgood New Member
    Nov 25, 2009
    Thank You
    Thanks I wonder if this will work on our seqouia as well??
  15. qponde51
    qponde51 Member
    Jun 1, 2009
    233
    sweet worked perfect thanx for the thread!
  16. fmap4life
    fmap4life New Member
    Jul 17, 2010
    891
    Thanks a bunch
  17. cbr264
    cbr264 New Member
    Oct 2, 2009
    58
    just did mine at 5K. no probs
  18. livinginsa
    livinginsa New Member
    Sep 12, 2009
    637
    It works on about anything. i even use it on my hybrid which has a button instead of a key to start the vehicle. I haven't found any fairly new vehicles that it doesn't work on but I am sure there is something that it doesn't work on.
  19. InfernoX
    InfernoX New Member
    Oct 12, 2010
    157
    Great write up, just did this. Thanks:top:
  20. X-cellent
    X-cellent New Member
    Oct 26, 2008
    22
    wow... i didn't know it was that easy... Thanks. :top:
