s/chargedxrunner06
Toyota Master Tech
- Feb 20, 2007
- 1,166
K2 wanted me to do a write up on this and hope it makes sense, really basic and easy to do, I recommend this even if you don't think it may be a problem, at least it will one less thing to deal with later (preventive mod)
Supplies needed
Aluminum strip 1/8" thick 1" wide and at least 28" long
Tools needed
1/4" drill bit
5/16" drill bit
Drill
Hammer or Rubber Mallet
Vise
Tape measure and pencil
Start by removing far bolt on rear of fender (10mm black bolt) underneath ground effects, remove parking brake cable clamp bolt (12mm silver) just above rear leaf spring,I measured mine and needed 12-1/2" long strip on both sides, yours should be about the same, drill a 1/4" hole on one end about a 1/2" in, place strip on truck and line hole with rear fender bolt use a pencil and mark where the bend will be at the truck frame (about a 25 to 30 degree angle) place the aluminum strip in a vise at the mark and fold by tapping on it with a hammer or rubber mallet to about a 90 degree angle, place strip back on truck and use the existing black 10mm bolt for fender (install hand tighten only) hold strip and line with parking brake cable bracket mounting hole (on frame) and mark for 5/16" hole then line up the brake cable clamp bracket with 5/16" hole and mark for 1/4" hole for the clamp stay pin remove and drill the 5/16" and 1/4" holes, install the two existing bolts and repeat for other side. This really stiffened up the fenders and should have no problems with them cracking after this mod is done.
Supplies needed
Tools needed
1/4" drill bit
5/16" drill bit
Drill
Vise
