Write-Up: Transmission Fluid Change
Discussion in 'How-To' started by Stevenredx, Apr 2, 2007.
  1. JFrame
    JFrame Member
    Dec 9, 2011
    654
    When pouring the new oil in via the shifter do you pour into the hole that the tip of shifter goes into or do you pour into the space around that hole?
  2. deanbhula1
    deanbhula1 New Member
    Jun 2, 2009
    213
    I think it's all the same area, if I understood your question. The part the tip goes in is just the thing that says what gear to be in corresponding to the position of shifter.
  3. JFrame
    JFrame Member
    Dec 9, 2011
    654
    The tip of the shifter had grease on it so I didn't really think I should pour the transmission fluid in the same spot as where the grease was. I ended up just waiting till my roommate came home and had him take me to autozone to get a pump. $7 and was super easy to just go through the fill hole at that point.
  4. cammedupneon
    cammedupneon New Member
    Jan 15, 2012
    15
    Very helpful thank you !!!
  5. tech86
    tech86 New Member
    Jun 2, 2012
    32
    Will be doing this next week. Cant wait!
  6. triple6
    triple6 New Member
    Dec 22, 2012
    39
    can't believe I haven't done this yet pics didn't show up tho maybe cus I'm mobile did you just order the oil online?
  7. sanchleo
    sanchleo New Member
    Oct 12, 2012
    35
    how does the container look?????
  8. X-MOKED U
    X-MOKED U New Member
    Sep 14, 2012
    1,228
    why wont it show the pictures :dontknow:
  9. chatt x
    chatt x Member
    Aug 21, 2012
    344
    Maybe the pics are no longer available. It's an old thread. Changed over to MT-90 last weekend and DAMN!!! What a difference $16 a quart makes!
  10. X-MOKED U
    Sep 14, 2012
    1,228
    seems simple enough i've done oil changes my whole life i just never did this... kinda wanted to have a peek before tackling it..but yeah thats what i want MT-90 i wanto do this the right way
  11. chatt x
    chatt x Member
    Aug 21, 2012
    344
    Super simple! Much easier with a helping hand! I ran clear hose from the trans to the engine compartment then put a funnel on that. About 10 minutes and done.
  12. X-MOKED U
    Sep 14, 2012
    1,228
    #132 X-MOKED U, Mar 11, 2013
  13. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,749
    9
    You could probably open the fill plug and have someone watch as you pour oil into the shifter and let you know when it's full. That way you know for sure it's full but you don't have to worry with a pump.
  14. X-MOKED U
    Sep 14, 2012
    1,228
    where is the fill plug located, and i suppose i can pour it in the shifter and when it comes out of the fill hole its full?
  15. justin13703
    Sep 9, 2010
    2,749
    9
    Fill plug is about half way up the side of the transmission on the drivers side I believe. Looks similar to the drain plug.
  16. GR6RR
    GR6RR New Member
    May 17, 2012
    667
    The write up did say dude bought 3... but used 2... required is 1.9
  17. rezrunner
    rezrunner New Member
    Mar 27, 2013
    14
    Eeek im at like 75k on my 08 iv done my engine oil with full synthetic all the time but iv never touched the tranny fluid. Im def doing this asap. One of the reasons being what was mentioned earlier, i researched it awhile ago and toyota says not till like 80k to do the tranny fluid but everyone on here is saying 30k kinda has me concerned :/ do u guys think its really bad that i havent done it?
    and also can anyone think of anything else i should be checking/changing maintenece wise around 80k? i just did the oil change at 75k im doing the sparkplugs soon.,and now the tranny fluid change. Anything else?
    And which royal purple product should i use in the tranny? i might want to just use that since i can get it locally but idk which royal purple to get
    #137 rezrunner, Jul 3, 2013
  18. dramad1
    dramad1 Active Member
    Mar 27, 2010
    2,367
    Coolant flush, brake fluid flush, rear diff, belts.
  19. X-MOKED U
    Sep 14, 2012
    1,228
    royal purple is an okay product MT 90 is the way to go for trans oil
  20. butters607
    butters607 New Member
    Oct 3, 2009
    3,826
    All of your fluids....cabin air filter, regular air filter
