Xii Street Drop
Discussion in 'Suspension' started by Kendall124, Nov 19, 2016.
  1. 30Birdy
    30Birdy Member
    May 3, 2015
    229
    You may want to make sure the lowering block is tight against the spring and perch. I had to drill my center hole out. The bolt that goes through all the leaf springs would not fit inside the hole of the block.
  2. 671PinoyDee
    671PinoyDee Member
    Feb 19, 2013
    51
    Thank you. I wouldn't want the whole axle coming out from under me so next day off Imma use some thread lock and screw on a second bolt right after the first bolt and in between I'm gonna put a lock washer. Over board lol....
  3. 671PinoyDee
    671PinoyDee Member
    Feb 19, 2013
    51
    Yeah same here I noticed the center hole was like a hair to small so I drilled it out a little bigger the first time I installed it.
  4. NHXRUNNER
    7,516
    127
    I've had my drop (mono leafs) on for 8 years.....never once had to re-torque the u-bolts
  5. 671PinoyDee
    671PinoyDee Member
    Feb 19, 2013
    51
    By any chance do u remember what your torque lbs was when u did it? And this was on a xii street kit????
  6. o0opackersfano0o
    Jun 23, 2016
    323
    54
    Toyota spec is 38ftlbs. Doesn't seem enough to me
  7. 671PinoyDee
    671PinoyDee Member
    Feb 19, 2013
    51
    Wow that's way too low. That's how I had mine at first it was way loose just for regular socket wrench not even a torque wrench hahaha. On other Toyota forums they're saying around 90 but on other car sites there posting 150lbs lol. I don't know 38 seems so low and scared to torque it 150lbs and sheer the bolts lol. Toyota's specs are for stock u bolts though. I wonder if the strength and material is a lot different for the xii beilsten lowering block and u bolts. Imma just do 90 and put thread locker lectite and then a second bolt backing up the first and then a lock washer in between the bolts hahahah trying to make sure it doesn't come loose again lol
  8. NHXRUNNER
    7,516
    127
    I think I did 80ish ft/lbs on mine
  9. Bizarroterl
    Bizarroterl Member
    Oct 7, 2009
    51
    Did you try contacting XII Performance and asking them what torque settings to use?
  10. MaK10-XRnR
    MaK10-XRnR Member
    Apr 13, 2017
    59
    How does this one lowering kit compare to the DJM as far as quality goes?
  11. NHXRUNNER
    7,516
    127
    High quality parts for sure.
    671PinoyDee likes this.
  12. 671PinoyDee
    671PinoyDee Member
    Feb 19, 2013
    51
    Ok thanks
  13. 671PinoyDee
    671PinoyDee Member
    Feb 19, 2013
    51
    Not yet. I should do that.
  14. 30Birdy
    30Birdy Member
    May 3, 2015
    229
    The instructions for the SOS kit say 75 Ft Lbs for rear U bolts.
  15. 671PinoyDee
    671PinoyDee Member
    Feb 19, 2013
    51
    Thanks guys!!! Here's an update.... I retightened mine to 90 torque.... I added a lock washer and then a second nut after that and red thread lock.. hahaha a little over board but after a month it seems to be working out just fine.... Here's a picture of my truck...
    #35 671PinoyDee, Jul 10, 2017
