XMPLRY 2015 TRD supercharged
Discussion in 'Member Builds' started by XMPLRY808, Apr 11, 2016.
  1. XMPLRY808
    XMPLRY808 Active Member
    Dec 5, 2014
    399
    73
    I finally got to refill my nitrous and tried it out [​IMG]
    With a 35 shot. Could feel it pick up a little more thinking to do a 50 shot
    Alter_Ego_808 and Hard Taco like this.
  2. XMPLRY808
    Dec 5, 2014
    399
    73
    IMG_0829.JPG IMG_0830.JPG IMG_0831.JPG I originally had 2 jl audio 13w6v2 in a sealed spec box in my Lexus then later decided to cut the box in half to run one between the rear seats. Since I just slapped in the box, it had issues... couldn't recline front seats much, box was blocking the seat belts, and since it was facing towards the front the bass couldn't bounce so it lacked bass. Then I came across the isobaric clamshell style which now I made to subs facing each other and now I can recline much more, there's access to the seat belt buckle, and it's much more louder. The angles were very hard to do I only used a skill saw and jig saw. I'm really happy with it :) now I just gotta carpet it and secure it
    #122 XMPLRY808, Mar 28, 2017
    Torspd likes this.
  3. XMPLRY808
    Dec 5, 2014
    399
    73
    Added a few things
    Some pedals lol
    Side note if you were wondering, switches:
    Top middle: purge for my nitrous
    Bottom middle: cut out switch
    Bottom right: nitrous switch
    Center console: R/L air bags and pump
    Also did the intake mod on the air injection pump
    Finally mounted my sub box solid and put carpet on
    devan08 likes this.
  4. NHXRUNNER
    7,720
    209
    Have you actually hit the nitrous yet?
    XMPLRY808 likes this.
  5. XMPLRY808
    Dec 5, 2014
    399
    73
    Yes I have. 50 shot
  6. GT7
    GT7 New Member
    May 22, 2016
    19
    How did that go? @ThomasMore66
  7. ThomasMore66
    ThomasMore66 New Member
    Dec 2, 2014
    7
    Let's hear more about this nitrous.
  8. XMPLRY808
    Dec 5, 2014
    399
    73
    Bad story..
    I originally had a 35 shot finally tried it after a car show from purging all night on the drive back home. I pressed the button could really feel the pull but then it stopped, my bottle was closed!! Ughh my wife that was with me felt it hit too was really cool. But my bottle was really low from purging. So I refilled it but up the shot to a 50 pill. Went out racing would use it, could feel it but not as hard as the 35 shot. Used up most of the bottle that night. Got home to find out the nozzle twisted and wasn’t facing straight into the throttle body. Epic fail but motor still running lol
    #128 XMPLRY808, May 8, 2018
  9. XMPLRY808
    Dec 5, 2014
    399
    73
    Front tow hook gotta do the back 67E819F9-ADCF-4C2E-B359-072A2B37BCAD.jpeg 9AB2FB9A-CA7D-4B14-A963-40248AC02D2F.jpeg
    devan08 likes this.
  10. ThomasMore66
    Dec 2, 2014
    7
    So, ever gotten back to using the nitrous?
  11. XMPLRY808
    Dec 5, 2014
    399
    73
    Not yet only cause we don’t have a track here in Hawaii and I don’t go out street racing anymore. Cops are out every night.
    I also had a problem with my brakes recently. Orielly rotors
  12. XMPLRY808
    Dec 5, 2014
    399
    73
    18EAF35C-BC10-4E63-AAB4-AC4458007AFA.jpeg Just got my tensioner mod from roostfactor at TW will install it later this week. Very simple to do but my truck is out of the garage and it’s drizzling. Still need to change my oil soon too...
  13. NHXRUNNER
    7,720
    209
    Please explain this mod, I'm not familiar with it.....
  14. XMPLRY808
    Dec 5, 2014
    399
    73
    It just makes the belt wrap around the pulley more for better grip and belt wear using the existing bolt holes
  15. XMPLRY808
    Dec 5, 2014
    399
    73
    It’s mainly for smaller pulleys to get more belt on the pulley for less slippage 7177BCF9-56FE-41E0-8322-8987136E6B49.jpeg removed stock bolts 6EFD29C0-27C3-4BD6-8E68-184F34E01F81.jpeg installed bracket with longer bolts and washers and the pulley. I like shiney things lol 2E2F8BE7-6D94-4CA4-AF18-5208DFAC24A1.jpeg 85B1D455-B863-41DB-8E56-DEC302C6D032.jpeg FC6CCDDD-57B0-4B3E-A089-4685DC5D5789.jpeg 36E366D4-4B8D-4CCD-9DA7-ED1388181EE5.jpeg It’s probably gained a 1/4 of more belt on the pulley!
  16. NHXRUNNER
    7,720
    209
  17. Roostfactor
    Roostfactor New Member
    Jun 10, 2018
    @NHXRUNNER, I copied this from my post in Tacomaworld. I am the one that makes these. It was something I just did for myself first then people wanted ready to install instead of fabricating their own.
    People might be getting some belt slip and not realize it. It's not like you are building boost and then the belt slips dropping boost to 0. It's more intermittent and progressive than that.
    The problem is we only have a 5 rib belt to grip an already small pulley at 3". This is with the correct belt wrap of 190° as guided by the idler pulleys. This give a total belt to sc pulley contact area of about 5".
    Once you start going smaller with sc Pullies, you not only lose belt contact area from the smaller pulley alone but also due to the position of the non adjustable idler pullies.
    Some info...at a constant 180° of belt wrap, pulley contact area is as follows:
    3.0. pulley 4.71"
    2.85 pulley 4.47"
    2.7. Pulley 4.2"
    2.5 pulley 3.9"
    That is almost an inch less contact area on the 2.5 pulley vs the 3.0 and that is not taking into consideration the extra load (hp) required to drive the sc with the smaller pullies installed or that you get less belt wrap the smaller the pulley.
    What the belt wrap mod does is restore some of the lost belt wrap which brings the belt to pulley contact surface area closer to stock.
    Hope this clarifies and sorry if I'm cluttering your post XMPLRY808. Bad ass truck!
    rjbiii and XMPLRY808 like this.
  18. NHXRUNNER
    7,720
    209
    Thanks for following up.
    Roostfactor likes this.
  19. XMPLRY808
    Dec 5, 2014
    399
    73
    Yea it’s all about surface area, more belt on the pulley... and thanks for the compliment roostfactor!
  20. XMPLRY808
    Dec 5, 2014
    399
    73
    Just got these Xii performance coilovers from my friends 4dr, 6 lugger. Had to remove the extended piece to go back to xrunner spec F3442384-0412-42E5-80C5-E2E19348C147.jpeg all cleaned up! 6922BF7D-8188-4817-A866-4408198845C6.jpeg 8E8B4F14-3653-449B-A530-45896E58F9B9.jpeg Can’t wait to go lower!
  21. NHXRUNNER
    7,720
    209
    I'd be all about it if it looked more factory.....just looks completely out of place IMO. I'm only running the 2.825 so I'm not as concerned with the belt slipping though.
