XRC Drop Kit
Okay everyone..
The drop kit consists of parts for the FRONT ONLY (To lower the back you just go get some blocks from a local shop).
This kit is 1.75" in the front (Effectively making a hair lower then 1.5" of drop)
****THIS KIT DOES CREATE NEGATIVE CAMBER*****
I was able to get within half a degree of factory spec of my alignment.
Most people are able to get their alignment within factory specs.
Please be advised, the alignment depends on your vehicle. If you have any other aftermarket items, changed suspension, etc, I do not know where your camber will end up.
This kit can also be purchased as a 1" drop if you do not want to go so low. I assume factory specs will be no problem with a 1" drop.
It is a CNC Machined spacer kit.
Here is a quick clip of the CNC machine cutting one of the spacers for validity :
http://www.youtube.com/watch?v=f1Ii1awFPCY
The bolts are grade 10 (strong as hell)
Kit cost $175.00 Shipped anywhere in the continental U.S. (additional charges for HI)
Here is what the kit consists of (Thank you Moorcheez for the pic):
Installation is quite simple.
The way this kit works, is the rolled steel pictured above acts as a spacer between the lower control arm and the spindle, effectively raising the spindle (lowering the truck).
Here is the close up of the spacer installed (disregard the 3 washers, this was a test fit)
And a pic of the complete kit on one side:
Okay - BEFORE
After:
Spyder327
I should be getting one of those from you sometime down the road Xrobber.
I dont think the prices went up. I know he had a GB for 155 over at CT which I got in.:D The bolts and spacers are great quality, def worthe the money
SWB X
This kit is a must have, just like the URD SS.
rob, can you get a picture of the clearance between the bottom of the bolts and the wheel?
dang thats a nice kit ...hey rob did yall ever fix the instructions and include the loctite?
CosmosX_az
"Magic Carpet"
Kit works great... Had some difficulty with the alignment but with a little help from droppedmytaco I was able to get the alignment done to specs today...:cool:
For the price that you pay, this kit is a must have. Once you go with the XRC, you'll never look at other X's the same
dermaestro
I've been very happy with the 2" XRC. Still can't find a shop to get the alignment within specs, but the last shop got it close. I'm not sure what the problem is, but the truck handles great with negative camber.
CosmosX_az
"Magic Carpet"
I got my A arms moved up about an inch and now my alignment was done with no problems...
Organic Mechanic
can you make them in custom sizes?
ill probably go with your 1in kit once I get my new wheels, but im going with oversized tires, and the 1.75 will probably be too much.
We do make a 1" kit. Let us know when you are ready.
TACO LIBRE
hey just wondering how much difficulty you had and how close you actualy got it? thanks Chris
LOL oops!
When I get my truck back I will get them. Sorry bro I forgot!
I really don't know yet, have the kit but still on the box it came! :biggrin:
CosmosX_az
"Magic Carpet"
My problem was the alignment... I had tried a few places and some wouldn't even touch it.. The closest I could get it was -3 on the right and -2.5 on the left... After I got my A-arms moved up about an inch and a half I actually ended up with slight posotive camber and my alignment shop got me into specs... Everything is workin great now...
