How to upgrade your diff
Redlantern
You guys happen to know if the LSD from the xrunners and the LSD in the Tacoma sport are the same? I just picked up a rear end off an 07 sport Tacoma that has an LSD on it. Will be switching it out with the one I have on there nowadays would like to do this mod if compatible.
Nashman
Came from a 2007. I spun it to make sure it's a true LSD and both sides spin in the same direction.
you may have to swap the lsd unit out since I figure it will have different gear ratio
Redlantern
makes sense. Damn i have the 3.73. i believe xr's have 3.15. Its ok, if it ever blows i'll just invest in a detroit locker.
Xcars_onfireR
I just pulled apart my diff to re shim the clutch pack and it brought it right back to new. I'd like to get one of he helper springs you got to give it a little more bite. But I'm supper happy to be spinning two tires again!! It really wasn't that hard or time consuming to do either
A tip to anyone pulling their rear diff out use a bar or peddle depressor against the seat to push the brake peddle down a bit. That will close off the ports in the master and stop all your brake fluid from ending up on the floor without having to crush your flex lines.
Nashman
takes longer to bleed and once ya release pedal just suck in more air up the lines
shane881510
Nash man I was looking at the stage two lsd kit from wier and will it work on our rear end. It removes the spring and use disk springs and a spacer
Nashman
I have installed that kit she is nasty as hell very aggressive for a truck's light rear end
was not to bad in the supra thou
but to answer you questions yes it's the same pretty much
simply put it's a drift diff or a truck with big tires
just went auto crossing on Sunday and the diff worked out so well in the dry this is my first really dry event that I got to push the truck
stage one is what I recommend
shane881510
I do a lot drag racing I need them to lock up good. I run 295 or bigger tire.
Nashman
Still no point the stage 1 will still grab just as good at stage 2 it's a clucht pack it's a 2 way lsd factory so there is no delay in lock up
It's not a torsen or viscous so no need to worry she will always go straight pending on tire pressure being =
shane881510
I just ordered the stage 1 and nervous about installing it. U made it
Look to easy.
Let us know how it goes since I have been waiting for another brave soul to try it before I take the plunge
shane881510
Well I'm done with the LSD. Just gotta put it back in the rear end and slide the axels back in. Wasn't as bad as I figured. My plates pretty much had no coating left to get off so. It's nice an tight now. Only advice I can give to make it Easyer is to make sure u line up the spring plate pins. Them sum b are tricky as f. That's the only thing I ran into that gave me a hard time. I broke one side of the long ones. Had to knock it out and replace it. But in the end everything came out good. I can't wait to get it back together. Two side by side black marks can't wait
Nashman
oh and you forgot wheel hop
