Everyone please comment!!
markgt531
i bounce from one forum to another every now and then to see what new and whats for sale, mods, events etc.
2005 NJ/PA
- 113k
- Bmw light gray (done by previous owner) original color BSP
- BHLM, bulb shield delete
- Yellow fog tints/ bulbs
- HIDs
- Previously equipped air suspension, currently on DJM 3/3 no notch
- Qa1 rear shocks
- URD trac bar
- 19X10 RPF1
- URD SS
- Bed cover (dont recall the brand)
- Recessed grill
- Trex eye lids
- Kenwood KSC SW11 powered sub (under seat)
- Aero turbine exhaust
- TRD seat covers
- Black carpet
- Black interior (except roof)
waiting for install
- URD sc, --- in the closet waiting for parts
- sparco seat
- AFE Y-pipe
2006 used daily (sold as of april 2018)
- 260k
- DJM 3/4, then went 3" blocks
- Blacked head light housing
- QA1 shocks
- HIDs
- Yellow fog tint/ bulbs
- URD SS
- TRD seat covers
- Enkei RZ-5 wheels
- Tail gate ez down shocks
- Dash cam mounted on rear view mirror
- Black carpet
- K&N intake
2005 / 2006
back When there were 2 of them
Brblkrunner
2009 x wt 197k, original everything (even clutch), bazooka 12, and pioneer head, had it 6 years
2012 x wt 24k, all original, had it 4 months.
Clean carfax on both.
Come here to get advice (mayb once a month) and luv to see other X's
Louisiana (aaaahhheee)
Not much of a mechanic, and don't trust just anybody wt my X's but if another member is close by me I may consider sum mods??? Hit me up.
Wz gona sell the 2009, keeping both now!
o0opackersfano0o
2009 x wt 197k, original everything (even clutch), bazooka 12, and pioneer head, had it 5 years
Baton Rouge LA
@NHXRUNNER see this is what I told you to do. Just buy another one.
Up here in Ontario. Black 14 XR, owned since new. I check in once in a while. Waiting until things start wearing out before doing a lowering kit, tires/rims, and then a SC. Unfortunately the SC costs a fortune with the exchange in Canada...but will still be cheaper than buying a bigger truck with more room and more power and with better MPG.
Only have a URD short shift for the time being.
Hamilton eh?? Burlington here!!
gunner76137
2007 Radiant Red
URD SS
URD Throw out bearing
CAI
DT long tube headers
Jardin catback
QA1’s
Pioneer DVD head unit
Custom sub box
12 in Kenwood sub
450 watt Boston Acoustic amp
Kicker 6 1/2’s
Kicker 6x9’s
7 color underbody lights
Xstag tri-fold toneau
rjbiii
Just joined im on Tacoma world everyday, but have been looking for something more performance based.
Im about to supercharge my 2013 6spd 4x4 double cab in about a month. Cant wait to partake in the boost life
Hawaiis Ribbon X
View attachment 22438 2009 SWB second owner purchased from member AZburnin after the second meet up st Virginia international raceway. The 09 is my second X. I purchased a 2006 RR new off the lot and sold it after getting the 09. I check the forum daily some days several times. I use mine for work and play, l am not afraid to use it as a truck or go do a track day and fun with a bunch of fast cars.
TRD supercharged with 2.85 stealth Pulley
Fuel pressure regulator mod
Doug Thorley long tube headers
URD 02 simulators
URD compition Y-pipe with big single magniflow catalytic converter and 3” exhaust threw magniflow muffler and tip
URD 160 thermostat
URD speed unlimiter
URD fuel pump kit
URD lightweight flywheel and stage 3+ clutch and Throwout bearing kit
Clutch accumulater delete
Coupe modded TRD short shifter and redline MT fluid
Coupe weighted shift knob
Toyota factory oil cooler
Detroit Tru-trac LSD with redline shockproof gear lube
AFE cold air intake with URD air filter and custom true cold air ram air inlet.
Custom track day tailgate spoilers
Custom street/daily use tailgate spoiler
E-fan
DJM 3/4 drop
XII performance sway bars
XII performance springs front and QA1 rear shocks
Custom bump steer correction kit
Custom front sway bar end links to correct for drop
Stop-tech BBK with isF rotors
SBC rear brake conversion
ATE brake fluid
Custom stainless brake lines front and rear as well as clutch line.
Carbotech hp10 pads front and rear
Custom brake cooling ducts and fans using screened fog light holes for inlets.
Firestone air bags to adjust rear spring rate.
Hood scoop delete
Grillecraft grill insert
Color matched. To the dash pad, radio face late
Your truck sounds super sick man! Love that sound!
RatfinkX
Embarrassing as this is I just saw this thread. 05 bsp in Saint Louis MO. I used to be good about poping on once a day at least. Started wanting to spend too much money and had to take a break
rjbiii
My 2013 dcsb 4wd 6spd manual
Located in Central Texas
Magnuson s/c
UCON EMS w/ 170 degree thermostat
URD stage III clutch
Lightweight flywheel
Walbro 255 fuel pump
Pulleyboys 2.8" qwikchange pulley
SOS Performance 2/3.5" drop kit (still need to install the front)
265/65/17s
Wet okole seat covers
Trd pro grille
Softopper
TRD Shift knob
OEM all weather flooring
Fog light anytime mod
AVS bug deflector & in channel rain deflectors
Oahu HI.
2008 BSP
I go on once a week.
SS drop, qa1, taco beef blocks, s2k antenna, tint all windows+front, revolution cover, Toyota rear wing, GREEN Xbrace, bhlm, flm, green HID fogs, led in and out, mini morimoto projectors, mx grill top and bottom, urd tcai, 6 bulb stl strobe kit, alt blinkers, Nst pulleys alt crank, w/p, subbin custom box, 10" jl w3, 600x alpine amp, window visors, wet okoles, painted BSP window control &a/c vents panels, white&green led gauge mod, Trd SS w/8" coupe mod and custom coupe shifter ball, dtlt, deleted cat y-pipe, mk2 exhaust, urd y-pipe, ucon, urd fuel pump 255, urd lighten fly wheel, Stage 2 Clutch
hypertaco
Sup y'all, I don't get on here near as often as I should. When I had my 2006 I was on here more, but didn't have money for mods back then.
Got my X in late March of this year from Florda. I live in Garner, NC
2012, Nautical Blue X, 19x10.5 ES9's, TRD Pro Grill insert, Truxedo Bed Cover, JBA exhaust, K&N intake, Kenwood DNX9980HD touchscreen, TRD short shifter, tinted windows, qa1 adjustable shocks in rear, 2 inch blocks in rear(hoping to swap those for leafs) and cut springs in the front, hoping to swap that with XII lowering springs soon.
Wants: front/rear sway bars,lowering leafs,lowering springs,S/C,performance clutch,long tube headers,trutrac lsd
rjbiii
Welcome back! Sounds like a good list youve got going for mods
LilRed
Hey everyone! I do not get on here as much as I'd like but still like to check in once in a while. I had an 05 XR (was Radiant Red) until I bought this one ('08) from another XRU member who I met at a meet in Daytona. I am originally from Destin, FL then lived in Orlando for a bit and I am now in Atlanta. I'm relativity activity in the car meets around the area.
Mods:
TRD supercharger w. URD 2.85 pulley/TRD CAI/TRD SS/URD Y pipe and exhaust/APR X-1 tuned by TMS/Tundra Brake Booster&Master Cylinder/RetroFit Headlights/XII suspension (lowered)/All maintenance done by me with 170k on the Odometer (I know it's not a mod... but still proud of this)
na-mr2
06 swb, 60k currently installed afe cold, afe catback, 18x9.5 gramlights, qa1s, urd short shifter with recent coupe mod, full headlight retrofit with projector fogs, tundra bbk
To be installed:
Thorley long tube, urd y pipe, 1” blocks (currently on 2”), intake manifold with 76mm tb and spacer, intake manifold spacer, ucon (still need components), urd trac bar, 19x9.5/10.5 weddsports, full sound system (components, coax, sub and amps). Waiting on group buy sway bars, sos performance sequoia master cylinder upgrade
Chris Griteman
Ohio
Red 05 x runner atm just fixing her back up looking at tons of stuff though but I do have a urd simulator and two 500 watt 12's bumping right behind the drivers seat and i got it out of Virginia up by toledo now
Cal Frez
just wanted to start a post to see how many people are on xru. The site is not as active as it use to be and we need to get it going. Please post if your on here once a day or every other day and what you have. I no there’s tons of trucks on here but a lot have sold. Post a pic of ur truck and where your from. And mods if you want. And let’s make xru great again!!
Been away from the site for a while.... my bad... to the good people at X Runner Underground, keep yoru heads high, you have a remarkable vehicle and one that is becoming more and more rare. Just try to find one for sale!!!!
crzyhawaiian808
Still here!!!! 2010 BSP x-runner on Oahu.
URD mk3 cat back (have problems with the exhaust tip fitting in the center of the exhaust cut out)
URD TCAI w/ maf calib (idles about 1500 at start up is that normal?)
URD short shifter
TRD shift knob
Morimoto led projectors w/BHLM and led fog lights.
Also i really want to add headers and y-pipe but I’m trying to scour the internet and forums about deleting the cats here in Hawaii. I know there aren’t any smog laws just hesitant about if safety checks will pass and the loudness in the cab.
I don’t see much x-runners driving around these days :(
