09+ XRs lsd mods?
808XR10
ok peeps with 09-11 Xrunner with the POS auto LSD, did anybody try modding the rear diff and putting an actual aftermarket LSD. trutrac and such brands? i wanna find out if it possible if not then its time to get rd of my XR. :frown:
on the bright side im going to get a tundra crew max 4x4:rockon:
lmk guys
Toon714
i have the trutrac sitting in my garge lol. havent got time to install it. i think the trutrac will elminate the gay factory auto lsd.
808XR10
lmk or post it up when you get it installed.
i have an os gieken thats waiting to be installed
i heard good things about os giken from gadget. ill wait for a little while more and extend my xr's life
ive read in another forum that we might have to change the entire rear end and that the auto lsd light will be on all the time. abs malfunction and such will be encountered. :frown:
Haha, that's good bro. One hell of a family car haha. Stock putting close to 400hp :vroam:
if i had the same year xr as yours then i prolly would keep it. lucky you
revobreaker
I doesnt work well, not a real "posi"
It just uses the brakes. It will apply brake to one wheel or the other
There was someone with a 09 that put in a trutrack and had no problems.
808XR10
I guess there's hope then. do you know who that person is?
darthyota
you forgot to mention about all the heat the get generated from using the brakes like that and end up causing your brakes to fade badly
That does suck a bit. I suppose it could be worse though. If it becomes something I can't stand, I'll just look into swapping it out.
FireB
How much does this tru-trac thing cost?
I heard from my mechanic that changing LSD is PITA and cost a lot of labor hours?
What are the estimated cost you think you are going to spend on the swap?
darthyota
well in my last toyota truck i put a spool in the rear diff in about 5 hours in my garage with out power tools so i would imagine about the same for an x being the rear end is essentialy the same
Top
