SignUp Now!Here are the stats from APR, for their fuel rail. :top:
APR 4.0L Toyota Fuel Rails
APR Fuel Rail kits are high-performance fuel delivery system that is designed to properly
supply the additional fuel needed for high boost/performance applications. The kit can be
ordered in various stages from rails only to a fully assembled set of rails with a high flow
adjustable regulator that will support our massive 386L in-tank fuel pump.
These kits are direct bolt-on replacements of factory fuel rails, complete kits include all
stainless steel braded hoses and AN factory style quick disconnects for quick and easy
installation. Utilizes the factory fuel dampener to prevent unwanted pulsation pressures,
there are two 1/8” female pipe taps for pressure transducers, gauges or additional fueling
devices. APR Fuel Rails are machined out of aluminum and are hard black anodized for
protection.
The 4.0L fuel rails are offered in 5 different configurations:
1) $389 Fuel Rails Only – includes all mounting hardware and four -6AN rail end fittings
2) $569 Complete Fuel Rails less regulator – includes all parts needed to assemble and install (less regulator)
3) $689 Complete Fuel Rails – includes regulator and everything needed to assemble and install
4) $749 Assembled Fuel Rails - SS hoses are cut and assembled, includes regulator and everything needed to install
5) $928 Assembled Fuel Rails and 386L pump
Hmm, can't find these anywhere? : /
And they aren't shown on APR's Website unless im blind : / would really like some red ones...
There is nothing to see there, move along.....
I think I posted the pictures in my build thread. Factory quick connect to 3/8" or -6AN, into fuel filter. Then -8AN Aeroquip PTFE hose from filter to rail to FPR. Then -6AN back.
Just wondering, is this something you just want to do, or is it something you think you must have for the power level you are running?
DoubllD might.
