Biggest Tire Size Without Rubbing
To make a long story short I want a set of tires that run 2" bigger in diameter than factory (29" in lieu of 27"). I know there are a lot of folks on here that run bigger wheels like 20's and are probably pushing a larger tire. Does anyone have first hand experience running a larger tire (like 255/55/R18) and can provide feedback on whether they rub while driving hard? I can't go to a smaller diameter wheel because of my BBK.
rennurx
Front, 255 35 20, offset 15, 20x9. Rear 315 35 20, offset 20, 20x10. 2" drop. No rubbing.
*IrunnIt*
Yes It was fine, it was stock height at the time
hrspwr236
275/40/20 on 20x10 et 25, very slight rub on full lock just before full lock no rubbing. Stock ride height.
So you have a 28.7" tire that rubs whereas the other fellow had a 29" tire that didn't? Is your offset/backspacing different than the factory wheel?
Coupe
I have a stock wheel with a 255/50/18. It is a 28.0 O.D.
No rubbing w/ XII drop.
hrspwr236
20x10 wheels with et 25 the factory wheels are 18x8 with et 30
