The correct answer... is this depends vary much on the individual. We all use our trucks different and like different things. I have been currently running C3 R8 for the front and C2 R7 for the rear and use my truck as a daily driver. I am using a Eibach Spring 2.50 inch I.D 1200.250.05505 on the front which is a 550 spring rate with my Viking 2 way adjustable Coilovers. I am currently running the factory X-Runner rear leaf springs with a 2 inch block also and the Viking 2 way adjustable rear shocks. Per Viking's instructions, rebound should be set 2 to 6 clicks higher than compression. In simple terms... the main job of a shock is to control the bounce of the spring and a spring is to carry the load. If you are telling me that the truck is very bouncy... my guess would be that the shocks are set too soft and need more compression unless the spring rate is too high for what you are wanting. If you are telling me that the truck is to rough/stiff than the compression is too high or the spring rate is too high. Bounciness can also come from the suspension sitting on a bump stops. Check to see what kinda clearance you have on your front and rear bump stops when the truck is sitting on the ground. You can check out my set up at
https://www.tacomaworld.com/threads/i-want-a-truck-that-toyota-never-made.690223/page-9 . I would say... try my setting as a baseline and drive around for a few days. If you don't like it... make a small adjustment only to the front or rear but write these adjustments down with notes... why you made the adjustment and this will help you dial in your suspension to your liking. I have made hundreds of adjustments trying to figure out what I like and every 6 months or so I may make a slight adjustment because my taste change. Hope this helps
Thanks
@sshadow69.
Just want to give some background info to this story so maybe it can help me dial in this suspension.
Before suspension modification, heights were:
FDriver: 29 1/2"
FPassenger: 30"
RD: 31 1/4"
RP: 30 5/8"
Pops and installed the 2inch steel drop block by DJM with the Vikings 2 way shock for the rear. Upfront went in the Strictly Street Viking coil overs with 2.55 ID 10 height 650lb springs. Now I don't know if orientation of the coil over shock will play to the jolting ride. I have the shock installed with the C & R knobs at the bottom. Reason to stating that is due to the fact that when i lowered the coil height to drop 1.5", it felt as the coil inside had no preload and I can move the coil by hand while being installed in the truck. I drove the truck with the new heights of:
FDriver: 27 1/2:
FPassenger: 27 5/8"
RD: 29 3/8"
RP: 28 3/4"
The setup to these were 7C and 9R all around. The drive was not so great due the bouncy-ness and much noise from the suspension due to much stress im sure. I played with different settings and finally said to increase ride height in hopes to have more load into the spring.
Current heights are:
FDriver: 28 1/4:
FPassenger: 28 5/8"
RD: 31 1/4"
RP: 30 5/8"
Settings are currently 8C and 10R for the front and 7C and 10R for the rear. This is still creating a bouncy ride. A possible issue is that I dont know the difference of feeling too stiff vs too soft. I use the truck for daily driving with some spirited driving 1-2x a week.
Let me know yalls suggestions based on the info above.
