Group Buy II
I have had an inquiry about the deep oil pan. So I am going to see if I can get enough interest to do a group buy.
I need to get a minimum of three (3), which will be a small group buy.
This is a pricey mod. Cost is $1100. This includes:
1. Oil Pan
2. Oil sump pick-up tube spacer.
3. Stainless bolts, washers & lockwashers.
4. Toyota gaskets (2) for the oil pick up tube.
5. Toyota FIPG
6. Four (4) BMW trap doors.
7. A magnetic drain plug (gold plug).
Pan is machined from a single block of 6061-T6 aluminum with the baffles heli-arced into place. If you use a large oil filter, capacity is 7 1/2 quarts. You will probably loose 1/4 quart if you use a regular oil filter.
Installation is pretty easy. I have done a write up.
http://www.xr-underground.com/vb3/showthread.php?t=45943
It will take about 4-6 weeks from when I cut off the group to finish and ship the oil pans.
Pricing includes shipping to lower 48 states.
I would need a deposit of $250 at the close of the group buy. If you want to break up the purchase in payments, I will do a law-a-way plan for you. You can make payments over 6 months, until you get the pan paid for, then I will ship it to you. The balance to be paid prior to shipping.
This is not an item I plan to keep in stock. I will run an another group buy when people show interest.
0. Coupe
1.
