Coupe Oil Pan Spacer Sale
fishsticks
Because fast lifted truck.
Will these clear the front diff on a 4WD truck?
Coupe
The 4 x 4 oil pan is a different design than the X-Runner. The will not bolt up. You would have to swap out the upper oil pan to use it.
I do not know if it would clear the diff.
Coupe
Yes.
I do not have any pans, but I do have spacers, both with & without baffles.
Coupe
I have four (4) spacers left.
Two (2) with baffles.
Two (2) without baffles.
Coupe
I have three (3) spacers left.
One (1) with baffles.
Coupe
I have two (2) spacers left.
I have a loose baffle that can be added if desired.
BMWtech
Coupe you're Pm box is full. Looking to buy a spacer. Local pickup in Houston if thats possible. Pm me I could pick it up tomorrow.
Coupe
I have one (1) without baffles.
This is the last of the run.
Coupe
I have two left.
I found one at the office, I was using for mock-up.
Both of these do not have a baffle. I have a loose baffle that could be heli-arced in place if desired.
Ziggy297
Coupe I'm interested. Do you have the loose baffle still? I can TIG that in myself
