Whitebeauty
- Oct 15, 2011
- 5,237
SignUp Now!No, you have the 4x4 oil pan. Coupe's fits the 2x4.
Yours is pretty deep in comparison to the 2x4 so you are in pretty good shape over the XRunner folks.
Theres no point. The 4x4 pan is good as is. If you want to change that area go for a dry sump setup, thats a true upgrade.
yeah, do you know what the 4x4 even is and why its not necessary on it?Do you know what the coupe pan even is?...
Ours are easy. You'll need to PM me.
These last few posts really crack me up. To point out who a "smart one" is, doesn't always equate to the intended purpose.
If the upper oil pan is swapped, yes, then you can mount the Coupe pan to the 2x4 pan.
If you are truly adamant about having that bad boy of a pan on your engine, then go for it. But let it be known, that the 4x4 oil pan set is not known for spinning rod bearings like the XR oil pan. The 4x4 pan even works very well off road at at strange angles. O_O
The one thing that makes it worth it to me, it that it would be similarly deep as the 4x4 pan, but more capacity.
