I think this is an area thing. What I am really curious is what are the HC, CO, Nix levels with just the rear cats installed?
I have front and rear cats and I am willing to go have a sniffer test done to establish a baseline. Is there anyone that has rear cats only willing to do the same thing?
NoX Levels. With OBD II cars, this really doesnt matter. The OBD connector reads the computer to make sure everything is working perfectly. If the computer says everything is A OK, then you are good to go. (no CEL's). There are ways to pass this. Our Viper buddy has a Gen II Viper with 1,600 hp to the GROUND!!! Anyways, he is running an AEM but when it comes to emissions he plugs in another computer that tells the OBD connector from the bench (emission machine) that everything is perfect...when it actually isn't.:rock:
We have 4 cats. Dont you only need at least 1 or 2 cats and a tail pipe to pass?
We dont have emission laws here so I have no clue
No, If your car comes with 4, it should have 4. If you remove 2 and CEL hasnt come on, good. You will still pass. If your CEL is on it is due to your O2's not seeing a difference in tempature between the 2 banks. That is when O2 sims come into play or when a good tune works out well.
My mustang had zero cats out of 4, missing 2 O2 sensors, 3 times as much fuel, S/C all sorts of stuff. But I got the stock ECU flashed/tuned and I had no problems.:top:
-Ant.
