gregincali
- Aug 18, 2007
- 1,246
thanks I was thinking bout going with the TRD. But Ill stay with my URD
SignUp Now!I noticed the B&M is noisy but I also noticed that if I drove around with the stock shifter knob off it was a lot more quiet. I purchases a new shifter knob that I am hoping will dampen some of the noise. It should be here soon
:top:
Hey guys,
I just bought a used URD ss from HVM. Anyone have a copy of the install instructions they could scan and either post up or send me. I would appreciate it, thanks.
Pete
tucanpete88@hotmail.com
:hmmmm2: Awesome info, but I have a question. If the shifter rods are not identical at the point of measurement from the dash, how can these numbers be accurate? In other words, if one is slightly bent forward, or back, or is more straight, or longer or shorter, fatter or thinner? Would this not throw all the calculations out of sinc? It would seem to me the measurement would be at the movement near the bottom of the shifter, not the top or middle. :hmmmm2:
:top:
It will help. I have a solid mount arm with a URD, I noticed a little whine in 6th gear only. I put a TMW A6 Leopard shift knob.
It pretty much damped it out.
Identical or not, the measurements will give the distance for the "throw" between each gear. Technically... you could measure from a completely different location but the distance between gears will still come out the same. Maybe that makes since... :hmmmm2::laugh:
nice comparison. need to throw that Coupe modded URD SS in the mix though.
