Just hit 60K, and wondered if I should also change the belt
Edgeman
Just changed the transmission & differential fluids, getting ready to install a new set of plugs & flush my brake fluid.
Since this is my daily driver, and my normal "road trip" vehicle, wondered if I should also swap out the serpentine belt as a preventative maintenance measure.
The original belt is currently 5 years and 60,000 miles old, and doesn't appear to have any abnormal wear or strange noises. Since timing belts normally have a 50-60K recommended change interval, I wondered if these have a similar lifespan. Should I let it ride or swap it out now. How long do these actually last?
I prefer NOT being stranded on the side of the road during one of my weekend trips...especially during the upcoming holiday season.
TIA!
STONER-X
I just hit 74k still on first set of pads and belts.. I'm about to do a major tune up myself
blackx-runner
"White Flash"
Its cheap and easy to do on our trucks, since you're doing everything else might as well do the belt too, then like was said you have a backup in the old belt.
X_Less
Threads like this make me feel like I've neglected my truck :(... 94K miles on original belts (i did spark plugs at 90K miles [And they seemed to be in "ok" shape]) and fluids
Edgeman
I'm trying to make this truck last indefinitely, so I don't want to cut any corners when it comes to routine maintenance. For me it's whatever Toyota recommends, unless I think it should be done earlier. I also try to stick with Toyota parts, so I have to go online to find the best deals. I can always beat my local dealers on parts...even considering what I have to pay for shipping.
I haven't had any issues with the serpentine belt, but it's getting some miles & years on it. $32 is cheap insurance.
hottacoX
I have found village Toyota to be pretty reasonable online
Edgeman
Link?
I generally do part searches for "Toyota Parts," and compare prices from the different websites that pop up via a Bing search. My latest purchase was from the Toyota Parts Zone, which was a few bucks cheaper than the other 4-5 websites I stumbled across for OEM Toyota parts.
hottacoX
Right on bro! Yeah if I recall parts zone has slightly better prices but wouldn't sell to me using a Canadian visa.... EVEN though it was shipping to my is mailing addy.... Crazyness I tells ya CRAZY
Edgeman
Noticed my X didn't have a belt routing diagram...strange. A quick online search took me to the Tacoma World website where someone had posted a PDF page from the Toyota factory service manual showing the procedure and the belt routing diagram:
http://www.tacomaworld.com/forum/technical-chat/13987-4-0l-serpentine-belt.html
It also led me to a FJ Cruiser website that someone had posted a maintenance procedure for changing the idler pulleys & tensioner.
http://www.fjcruiserforums.com/foru...154-idler-pulley-bearing-failure-what-do.html
Good info!
