Radiator Over Flow Tank
LOW AND BLOWN
Did some searching with little success, what are you guys using to get the dark stains out of the overflow tank?
Coupe
This is a little thread jack.
I have not done any stain removing, but I did add a hose to the over flow, so when, it does overflow, it does not trash my engine compartment.
LOW AND BLOWN
Ok thanks, I finally just used a bristle brush like what you would use to clean baby bottles
TRDreams
The best trick is to toss a half cup of rice in there, a few second of brake cleaner spray to get some fluid in there to swish around, maybe a little concentrated cleaner for fluid aswell. Shake it real good. Will look BRAND NEW, promise I do it quite a bit, gets rid of everything internally
