Royal purple HPS
If you have no cats, then you'll be fine.
High ZDDP content will aid in wearing out catalytic converters prematurely. If you have a but the flip side is that it protects
your engine better, with I high count.
A good catch can setup will help negate the negative effects of the high ZDDP content because the engine won't be consuming so much oil through the PCV system.
smftexas86
I realize this is like 2 months late, but while I was installing the trac bar and drained the gear oil I was gonna put in royal purple. for $22/quart, I was wondering if I was buying the nectar of the gods by accident.
I keep asking the same thing. Maybe its Royal?????
