Spyder327
- Jan 14, 2007
- 7,098
- 1
Toyota Part Numbers for maintenance items
I'm making this for everyone based on rpmspeedyblue's idea in another thread.
LIGHTING
Tail/Brake Light Bulbs (Rear combination)
--27/8 Watt # 1: 90084-98027
--27/8 Watt # 2: 90084-98037
--18 Watt: 90981-11059
Turn Signal Bulb: 90084-98062
Third Brake Light Bulb: 90981-12010
Fog Light Bulb: 90981-AD002
ENGINE
Oil Filter: 90915-YZZD3
Drive/Serpentine Belt: 90916-A2001
Valve Cover Gaskets
--Right: 11213-AD010
--Left: 11214-AD010
COOLING SYSTEM
Coolant Temperature Sensor: 89422-06010
Radiator Hoses
--Upper: 16571-0P020
--Lower: 16572-0P020
Thermostat: 16031-0P010
Water Pump: 16100-09470
EXHAUST
Exhaust Manifolds (with front catalytic converters)
--Right: 17140-0P010
--Left: 17150-0P070
Exhaust Manifold Gaskets: 17173-0P010
Exhaust Pipes
--Front Pipe
----Right: 17410-0P020
----Left (2WD Specific): 17450-0P020
Muffler and Tail Pipe (XR Specific): 17430-0P020
BRAKES
Discs (Front): 04465-04070
Rotors (Front): 43512-04041
Calipers (Front)
--Right: 47730-04080
--Left: 47750-04080
--Caliper Piston: 47731-0C020
Shoes (Rear): 04495-04010
Drums (Rear): 42431-04050
HEATING/AIR CONDITIONING
Blower Motor: 87103-04040
Compressor Clutch: 88410-04061
Condenser: 88460-04210
Heater Core: 87107-04060
FUEL DELIVERY/AIR INDUCTION
Engine Air Filter: 17801-0P010
Mass Air Flow (MAF) Sensor: 22204-0D030
Fuel Injectors: 23209-39015
Fuel Pressure Regulator: 23280-31010
Fuel Pump/Filter: 23300-0F010
Throttle Body: 22030-0P010
--Gasket: 22271-0P010
IGNITION
Ignition Coil: 90919-A2001
Ignition Switch: 84450-71010
Knock Sensor: 89615-06010
STEERING
Power Steering Pump: 44310-04130
Tie Rod Boot: 45535-07010
Tie Rod End: 45046-09330
Inner Tie Rod: 45503-09360
Steering Shafts
--Upper: 45210-35260
--Intermediate: 45220-04010
--Lower: 45203-04010
SUSPENSION
Control Arms (includes ball joints)
--Lower
----Right: 48068-04030
----Left: 48069-04030
--Upper
----Right: 48610-04010
----Left: 48630-04010
Coil Springs
--Right: 48131-AD180
--Left: 48131-AD190
Leaf Springs
--Right: 48210-AD020
--Left: 48220-AD020
Shock Absorbers
--Front
----Right: 48510-A9640
----Left: 48520-A9310
--Rear
----Right: 48530-A9330
----Left: 48540-A9200
Stabilizer Bars
--Front: 48811-04100
--Rear: 48812-AD030
If anyone has any other things they would like the part numbers to, let me know and ill see if i can find them and add them to the list :top:
LIGHTING
ENGINE
Valve Cover Gaskets
--Left: 11214-AD010
COOLING SYSTEM
Radiator Hoses
EXHAUST
--Left: 17150-0P070
Exhaust Pipes
--Front Pipe
BRAKES
Calipers (Front)
--Left: 47750-04080
IGNITION
STEERING
Steering Shafts
SUSPENSION
--Lower
--Upper
Coil Springs
--Left: 48131-AD190
Leaf Springs
--Left: 48220-AD020
Shock Absorbers
--Front
--Rear
Stabilizer Bars
--Rear: 48812-AD030
