Here's the two hardest wires to find when installing an in-dash navigation system in our trucks. I figured having these will help some people out in the future.
The VSS wire is located behind the glove box on the 2nd plug from the bottom of ECU. Its the purplewith white stripe wire as seen in the pic with the red wire tap already on it. :top:
Photo from andybellus@TN
Photo from Pb@TN
The reverse is a little easier to locate. It's behind the drivers side lower kick panel. The red with white stripe wire :top:
Photo from Pb@TN
