X-Runner Rebuild
Scyko
This is my first thread post and a very unfortunate one at that, Back story i bought my X on October of 2016
and fell in love with it as we all do, but all good things must come to an end and mine ended on April 14, 2018 when i hydroplaned on a turn sending me into the ditch,causing me to roll over. Normally that would be the end of a vehicle but i would be able to sleep at night knowing that i sent an X to the Boneyard so as the title says i'm rebuilding it. and i thought i'd show my progress.
Scyko
This is what she looked like before the accident, followed by after
TX-X
Sorry to hear about the wreck, but thank God you are ok. Quite a project, but bet it will be fun. Where are you located?
Scyko
So to start off i needed a donor access cab and Tacoma's reliability bit me in the rear on this. Since April i've been looking for a cab to no luck at all. Only tacomas i found were either first gen, regular cab, or wrecked worse than mine, until 2 weeks ago i found one. White access cab very minor dings, automatic ,but i could easily convert to manual
Scyko
Once i saw it was good i went to town gutting it, removed all interior, disconnected all the harnesses and removed the 6 bolts holding the cab on the frame
Scyko
Now that i had a cab i proceeded to remove my damaged cab, and since i didnt need it anymore out comes the angle grinder...bare with me these next pics aren't easy to see but needed to be done.
Scyko
Now the moment of truth doing the actual swap. (lost some pics but still have most of them)
Scyko
Had about half of mt truck inside the house
Scyko
with the undamaged cab on i began to paint and reinstall everything.
Scyko
everything that couldn't be saved and the slight mods i did to convert to standard, this is all i have right now done more to follow and i should be done by this Saturday, still need a hood and the driver side doors no luck finding any here
madtrucker
Wow! What a project?! You are going to know that truck inside and out, literally, by the time your done. It looks good. I'm impressed. Can't wait to see it all finished.
