Rotora Slotted or Drilled Slotted Rotors???
I've been doing alot of reading on the benefits of slotted rotors and drilled slotted. Not sure what rotor to go with? Any input please?
Slotted
- racing, autocross, larger trucks and SUV's, and vehicles that exhibit chronic brake problems.
- greatest amount of braking surface, helps keep the pads clean, and increases initial brake 'bite'.
Drilled/Slotted
- street performance application
- Tend to crack if the drilled hole has edge, inverted charmfer is recommed to prevent this from happening
- drilled holes help with cooling once the slots wear down.
- Slotting privides additional brake 'bite'.
- drilled provide an escape path for the gasses over the entire life of the rotor
Slotted
Drilled/Slotted
