JDMsneakerz
- Mar 2, 2010
- 6
looks damn clean!
SignUp Now!Any rear end shots? Is a 255/8.5 wider then a 245/9.5?
Yes it is wider
Not really.
The 255 is a wider tire then the 245. Even with the stretch the 245 only has so much tread that is usable. Once you start stretching that much , the sidewalls will start stretching (no change in surface area)
In this case of 255 on an 8.5" rim and 245 on a 9.5" rim, you will still have more tread contact on the 255 even on an 8.5" rim. It would be like putting a 255 on an 8.5" rim, and then one on a 10" rim. Surface contact will be the same, as the tire is the same width.
werent you the one with the custom 20" volks? what happened to those?
The +12 looks right on for the drop...how would +22 look?
Tire to the fender +10mm which would have more lip?
I was looking at 19x9.5.
