SignUp Now!No...you will have mad alignment issues.ok will the ss drop springs work with the djm???? can it get into alignment????
the tires will hate you, The toe will be so bad it will sound like one long burnout. I adjusted the toe as close as i could before i went to the shop
just use the camber bolts and eyeball it if your going to drive it to the shop to get it aligned. r u gonna go to island brake? cause don't take it to goodyear if at all possible...my home alignment was better than theirs....
the two bolts on the LCA can be used to adjust the toe as well, i don't suggest you use the tie rods to correct it because there's a higher chance of fking it up.
if you change the toe by using the lower bolts it will change your caster angle as well as your camber too.
what about firestone??? i might take it to scottys
any rubbing issues withis this drop on the driveshaft and how to fix if any. I heard a lot of different sotries saying that all truck are a lil different
