dramad1
- Mar 27, 2010
- 2,367
This morning I noticed a wet spot in my drive way, after inspecting my undercarage I found a slow drip of coolant coming from the inner cooler pump. It looks like there is a gasket in between the two sides of the housing on the pump, and this is where the drip is.
Is there or does anyone have a part number for this gasket, or can I use some rtv gasket maker on there? Also noticed the worm gear clamp on the hose going into pump needs to be replaced as well as the worm gear clamp coming out of the lower coolant resivor ( can't spell right now ) to sick to think. Looks like it had a slow leak and coolant has started to eat through the metal.
Anyone have similar issues?
