TRD Supercharger
RRXrunner12
i am selling my current sent up on a 2012 X-Runner. I have the TRD Supercharger with a 2.55 pulley installed on it. Still installed on my truck looking for $3k obo
What were you running for tuning?
That truck won’t run right on the stock injectors. You can’t “unflash” it. The TRD flash is permanent. What’s the plan for the truck after the blower comes off?
You would need the fit kit parts for the 05-11
FantasticMaxx
I may be wrong, but cant you guys just trade ECU's, so OP would have an original one and you'd get the reflashed one?
I'd be all over this if I didn't just blow all my life savings on a new home. :(
Unfortunately you are.....the ECUs can not simply be swapped.
o0opackersfano0o
If they are same part number they can be swapped but have to relearn immobilizer and have vin written.
TitanRattler813
Either way, I'd rather piggy back than reflash so that wouldn't really help
RRXrunner12
sorry for a late response.. i work at a local Toyota dealer the S/C is still installed on my truck at this moment.. the kit will be complete. if its someone local i can have my techs reflash the stock ecu.
RRXrunner12
i am trading in the truck at my job
The truck won't be worth anything if it won't run......I mean yeah you could take it off and limp it into the dealer to scam them but the truck will not run properly because the ECU is trying to run a map for forced induction with larger injectors.
TitanRattler813
Just to clarify, your plan is to have the techs reverse the TRD reflash back to OEM? The install guide explicitly says you will have to replace the ECU. Can't go backwards. So if you want to get rid of the supercharger you either have to get a replacement ECU or trade with the buyer
RRXrunner12
No i never said anything to reverse the reflash. I am selling the truck to the dealer with the reflash installed just no s/c
