Well I began installing the 2.85" pulley I got from URD today at 3pm. Just got through at 6:30(well kinda). Getting the old pulley off was a breeze. Installing the new one was a nightmare. I torqued on it for hours. Took the pusher off 10 times to make sure it wasn't loosening and I wasn't going to far. Well I got it about 1/8" from flush and the tools small threaded insert broke in two. Took it apart and cleaned the threads and used the second insert that was sent. It also broke and messed up the from 1/4" or so of shaft threading. So I am kinda stuck. The pulley is on enough to line up with the other pulleys.... just not perfect. I will probably have to get another part for the puller and try to make it perfect soon. But on my test drive it doesn't seem to have upped the boost any. It was approximately 6psi before. Now it is maybe 6.5psi. Not exactly the 1.2-2psi I was looking for. Could the pulley being off an 1/8" from flush cause this? Or could it be something else? And yes I checked and I did install the new APR pulley not the original. Any suggestions?
