AlexForbesR6
- Nov 5, 2009
- 66
So i had the NST crank pulley put on at the meet a couple months ago and a couple of days ago i found large oil spots all over my driveway right under where the front of myu tyruck is so i took it to the stealership (i have an extended warranty) and they called me and told my my crankcase seal was leaking and told me the warranty wouldnt cover it if they tried to cause of the pulley because if they said no or yes to whether mods had been performed an adjuster would come out anyways and see the pulley and say no(apparently it is an aftermarket warranty)...What do you guys think i should do...i am going to go up there now and talk to them (its at Star Toyota of Clear Lake) and see if they will put on my stock pulley, give me the nst one and then call the warranty company. If that doesnt work i guess ill get it home (which might be hard since i have no oil in it...think ill have to use my AAA) and put the stock pulley back on myself and then get it towed to a different dealership...question is i guess which dealership in the houston area (as close to kemah/league city as possible) has the best service and mechanincs and will they know i changed the pulley and then put the stock one back on?
Thanks for your help!!!
