They have to actuate the ABS module in order to bleed it.
I am going to say that it's the brake booster for now because it's kind of hard to get air into the ABS module
thats what i was thinking.... for the most part from what i understand is the abs module is bypassed untill the abs pump is actually used... and to track air all the way back to the pump it a long trip for a basic bleed job... that is unless the brake fluid didnt run dry while bleeding... i would say try it one more time... its all about good team work.. here is how i do it... im gonna try to simple for typing and reading lol
-have the person pump the once they are hard have them say "ready"
-then you open the bleeder
-as the pedal is still moving (i say once about half way) have say "close it"
-once the bleeder is closed say "closed" so the pumper knows it is ok to let up on the pedal
-you close it.. and when you are ready say "pump it"
then repeat these steps it has never failed me yet...
the key is to close the bleeder while the fluid is still shooting out... i also put i hose in a water bottle to keep it clean... and also i like to think if the brake pedal is let up a tad early the extra fluid in the line will help eliminate SOME air from getting sucked back in...
