SignUp Now!im on the way with a single
Yeah man, if you want those numbers, turbo is the only way for these trucks.ahhhhhhh just when I had my mind made up on the TRD setup I see these #'s, do you think with enternals the trd will ever be able to match the HP of the turbo setups?
You don't have to built your own kit... You just go to a performance shop and tell them what you want. Then drop around 7k and walk out with a turbo'd xr.The turbos throw down some good numbers, but youll spend a lot of money making that power useful. If they had a mass produced kit for our trucks thats one thing, but I wouldnt risk creating my own kit IMO.
then again, Im not that savvy when it comes to that stuff.
Hey. How are you running out of fuel pump at 7psi? Are you using an FMU or do you have bigger injectors? My pump was still keeping up at ~15psi. Oh yeah, that stock clutch of yours isn't going to hold up long. Mine started slipping anywhere in 2nd gear and higher at just 7psi. Congrats on the numbers though. If I were you though, I'd run a bit richer...
