I'm too stubborn to give up so easily. Giving up would say it is pointless to try and achieve something. Failure. Not happening.
The scars are only on the trust areas. Having the chance to look back over everything, it does look like the pistons have a bit more play in the cylinders than they should. Have to wait until Monday night to get them out.
I'm not using these heads again, as it isn't necessarry.
The passenger exhaust cam gear grooves between the teeth showed wear, due to chain tensioner failing.
Can't wait to see the pistons.
I tell you, I can damn near disassemble and re-assemble this motor in my sleep.
Only the piston that had the broken plug had knicks in it.
